clogged heat riser tubes
sierrapipe
sierrapipe is offline
PostPosted: Sat Oct 25, 2014 10:58 am    Post subject: clogged heat riser tubes Reply with quote
How do I unclog the heat riser tube? Has anyone used Zarwerks to purchase a K manifold or the heat riser tubes they sell? This is for a 1960 bug 36hp Intake manifold VW# 111.129.701 E Thanks
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Sat Oct 25, 2014 11:01 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=186857
http://www.thesamba.com/vw/forum/viewtopic.php?t=391833
From the FAQ's at the top
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
Aussiebug
Aussiebug is offline
PostPosted: Sat Oct 25, 2014 5:15 pm    Post subject: Reply with quote
Yep.
About 18 inches of stiff cable like an old clutch cable (slightly more than half the length of the hear riser). Cut it off with bolt cutters (it's very tough steel) at an angle so you have a point on one side. Put it in a battery drill and spin BACKWARDS so the cable does not unravel. Drive it in from both ends.
If you try to use a long cable and go right through from one end, the cable whips around too much.
Once you have a small hole through the gunk, you can turn it upside down and soak overnight in carb cleaner, drain and drill it out again - that will get a lot more gunk out and keep it working longer.
The main reason they clog up is that folks wait too long before rebuilding an engine - if you drive it for a long time with the car burning oil, it builds up crud in the heat riser and eventually blocks it.
The heat riser is an essential part of the single carb setup on a bug - it keeps the intake warm so the fuel stays suspended in the air-stream along that long induction manifold, and it also stops icing under the carb in colder weather.
Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Oct 26, 2014 10:32 am    Post subject: Reply with quote
Another likely contributor is the lack of a thermostat.
Juanito84
Juanito84 is offline
PostPosted: Sun Oct 26, 2014 10:49 am    Post subject: Reply with quote
Another contributor might be those who enrich the A/F mixture to make up for missing and mismatched parts.
If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine?
Aynthm
Aynthm is offline
PostPosted: Sun Oct 26, 2014 1:17 pm    Post subject: Reply with quote
I used muriatic acid every night for 3 weeks with a drain auger. Just don't breathe the fumes, they will dissolve your lungs.
BWD
Samba Mailman
BWD is offline
PostPosted: Sun Oct 26, 2014 1:42 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=519802&highlight=oxy+acetylene+torch
It's all in this^^^thread! Cool
BWD
JHC
member #2850
1966 Beetle
_____________________________
John S.
John S. is offline
PostPosted: Mon Oct 27, 2014 10:34 am    Post subject: Reply with quote
I had success with filling the tube with water, soaking overnight then laying it on the gas grill and cooking it full blast for fifteen minutes.
Makes the carbon build-up break up as the water boils.
Still need to use the cable and drill to finish honing it out.
Non-toxic also! Wink
SuperSamba Premium Member
Samba False Idol
SuperSamba is offline
PostPosted: Mon Oct 27, 2014 2:20 pm    Post subject: Reply with quote
Please see the FAQs above.
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Beetle - 1958-1967 All times are Mountain Standard Time/Pacific Daylight Savings Time
