analogmax Samba Member
Joined: September 27, 2006 Posts: 161 Location: Chandler, Arizona
Posted: Sun Oct 26, 2014 10:56 am Post subject: Wiper Motor question |
I bought this wiper motor at a swap meet yesterday and I'm not sure it will work in my Thing. You can barely make out the numbers on it, they look like 111 955 113 which I believe is for a 67 beetle but the shaft on it doesn't match. It looks like it would work in a Thing, all of the connections match with the exception of the ground (#31) connection is missing and the shaft looks right.
IHC Samba Member
Joined: April 30, 2012 Posts: 204 Location: Washington state
Posted: Sun Oct 26, 2014 10:26 pm Post subject: |
I used most of the guts out of one like that to make mine work. Can't remember why it would not interchange or why not all parts interchanged. |
Pbotsonis Samba Member
Joined: January 09, 2008 Posts: 506 Location: Parker, Colorado
Posted: Mon Oct 27, 2014 11:44 am Post subject: |
Since we're on the subject, can anyone tell me where to get these screws?
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Mon Oct 27, 2014 12:00 pm Post subject: |
You may use some parts from this but Things has a gear box that mounts it to the windshield frame and the shaft post has a nut that holds it on. That beetle motor is made for a chassie assy. Hope Al Capulco can help here. |
Posted: Mon Oct 27, 2014 12:40 pm Post subject: |
Once I took it apart I can see how different it is, there are some usable parts though so still worth picking up. Thanks for the replies. |
Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
Posted: Mon Oct 27, 2014 2:24 pm Post subject: |
see if you cant get ahold of Mike Basso, he took one I sent him and converted it to thing use..it was a SWF one, which looked a little different than that one. _________________ Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
https://www.thesamba.com/vw/forum/viewtopic.php?t=771024&highlight= |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Mon Oct 27, 2014 8:24 pm Post subject: |
That looks like a 2 speed 6v motor to me, not a '67. Just going by the shaft and connector block. SWF made a lot of wiper motors that look similar but are not very compatible. I have lots of those little screws, just send me a PM and you can have 4. |
Posted: Tue Oct 28, 2014 3:50 am Post subject: |
PM sent |
