waxhead Samba Member
Joined: January 19, 2004 Posts: 946 Location: Philly 'burbs
Posted: Sun Oct 26, 2014 5:20 pm Post subject: What is this thing on the engine case? |
Some kind of sensor or something? _________________ Mike B. |
Al Huva Samba Member
Joined: April 12, 2004 Posts: 81 Location: kelowna BC Canada
Posted: Sun Oct 26, 2014 5:31 pm Post subject: |
Hi looks like you have a fuel injected case and that wire and sensor i believe is for the computer |
IHC Samba Member
Joined: April 30, 2012 Posts: 204 Location: Washington state
Posted: Sun Oct 26, 2014 10:18 pm Post subject: |
Sensor for the computer diagnostic system they had on the cars. |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Mon Oct 27, 2014 6:05 am Post subject: |
Yes, the wire connects to the square plug for the diagnostic system and was only on 1974. |
JayC Samba Member
Posted: Mon Oct 27, 2014 6:55 am Post subject: |
I certainly do not have the knowledge or skills of the famous Domeck brothers, but I am not sure it was a 74 item only? I had one on my 73 when I pulled the engine:
I have not reason to believe that the engine in my 73 was anything but original. I bought it from the original owner and no mention was made of changing the engine.
I left it off after I rebuilt the engine. I know it went to the diagnostic plug. It wasn't wired to anything when I pulled the engine out.
jay |
Posted: Mon Oct 27, 2014 9:30 am Post subject: |
Very well could have been on some late 73 cars. Same as Beetle. The cars we have worked on that had this has been 74's. |
WD-40 Samba Member
Posted: Mon Oct 27, 2014 9:54 am Post subject: |
Is there a 74 (possibly 73)-specific flywheel that goes with this sensor? _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
Posted: Mon Oct 27, 2014 8:05 pm Post subject: |
If I read the microfitche correct That sensor started with vin 183 3026 060 with a date of 9-30 1973. This must be why I have only seen these on 74 cars. This had me thinking all day. Now if we know VW they could have started in 73 and our info from them is wrong. |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Mon Oct 27, 2014 8:19 pm Post subject: |
WD-40 wrote: |
Is there a 74 (possibly 73)-specific flywheel that goes with this sensor? |
yes the flywheel has 2 small pins on the back side of the flywheel. From the other Domeck brother
Posted: Tue Oct 28, 2014 12:33 am Post subject: |
Clip the wire and move on. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Oct 28, 2014 12:55 am Post subject: |
Thinking anything with a diagnostic plug had them- lots of T-4 s had them saw 2 pins on a flywheel- close together. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
SilverThing Samba Member
Posted: Wed Oct 29, 2014 6:18 pm Post subject: |
My 73 Thing does not have the flywheel sensor. The case casting shows that VW obviously anticipated it coming along, but the hole wasn't machined out on my case. My case was cast in May of 73. The sensor works in conjunction with a flywheel that had two pins. I want to say that VW discontinued the diagnostic system in 1977 or 1978. I've got a bulletin somewhere in my stash that mentions it no longer being supported.
The flywheel sensor when used in conjunction with the #1 spark plug wire sensor allowed the dealer diagnostic computer of the time to calculate very accurate timing. I think I read somewhere that it was accurate to within a tenth of a degree. Better than you can do with a strobe light... _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
