tschroeder0 Samba Member
Joined: April 14, 2008 Posts: 2096 Location: Boulder CO
Posted: Thu Oct 30, 2014 7:07 pm Post subject: uivalent |
So, what am I missing as far as some ground breaking new development?
you don't have to go back very far in the samba search history to find the not so great (to put it mildly) reports of the 2.5. At the time they came out there was much about the newly developed pistons well??, and its easy to find the thoughts tencent had on why he stays on the lower end of a 2 liter wbxer.
I am all for new developments to the wbxer, I think its cool, what I don't like are stories about members here spending the equivalent of a small fortune on something that may not be as reliable as the 1.9/2.1 |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 944 Location: Portland, OR
Posted: Thu Oct 30, 2014 7:21 pm Post subject: Re: uivalent |
tschroeder0 wrote: |
I like GW and agree with the above. I've bought an engine from GW and they helped with a warranty issue when it was needed. I do like to go fast(er) too, but every time I've had an engine issue I really would have liked a little reliability baked into the equation.
Get there and getting home with no drama is really the goal. _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2978 Location: Issaquah, WA
Posted: Thu Oct 30, 2014 7:32 pm Post subject: |
The difference lies in the wall thickness of the cylinders and the diameter of the cylinder mounting bores in the case. The old GW 2.5 used stock cylinders bored out to 97mm mounted in the stock diameter case bores. The thin cylinder walls caused poor ring seating and oil consumption. This new engine uses special cylinders designed around the 100.75mm pistons with proper wall thickness. The case bores have been opened up, too, to allow for sufficient stiffness in the bases if the cylinders.
Only time will tell how well this combination works out. But in concept, they've approached this new development the right way with the larger diameter cylinders and bored case, so I wouldn't assume it will have the same issues as the 2.5.
I agree with you, though. Paying huge money for a WBX that doesn't hold together is for the birds.
Dave |
Posted: Thu Oct 30, 2014 7:37 pm Post subject: |
i am not at all trying to knock GW.
Maybe the 2.5 has been more reliable than I know, I just know what I have read here and it seems much more on the negative than positive. The issues seem to have been around reliability and maybe the bigger issue of what it takes( and is it reasonable) for an engine like the wbxer that is expected not just to have more power but to run all day long fully loaded, to be punched out to these sizes...really, Im just wonder out loud. |
Posted: Thu Oct 30, 2014 7:43 pm Post subject: |
thanks Dave, that was what I was wondering. |
vanonimous Samba Member
Joined: October 19, 2013 Posts: 362 Location: Burien, Center of the Universe
Posted: Thu Oct 30, 2014 8:59 pm Post subject: |
Too thin cylinder walls is sort of a first mistake people make when going overbore. Trouble is it gets thin and warps as it doesn't dissipate heat well. Then it burns oil...Add iron liners into equation and yeah, bad idea. Much better bore case but then you run into meat holding studs in place. No free lunch in math.
So IMHO they are going into right direction even though a WBX with pushrods, 2 valves, ancient combustion chamber is mildly put inferior in design. They better have some light pistons. But GW is excellent in marketing. They have a true following that doesn't care, they buy. I have a friend who drops $5K for seats, no problem. Another 4k to make his A/C work, sure.
I just sit and watch in amazement. _________________ If happiness is being a mechanic, owning a Vanagon is nirvana.
Lighting upgrades: https://www.thesamba.com/vw/forum/viewtopic.php?t=578291 |
tjet Samba Member
Posted: Thu Oct 30, 2014 10:45 pm Post subject: |
D Clymer wrote: |
I wonder if they will sell those 100mm cyls as a kit.
My wbx with a 76 mm crank would be a 2424 lil monster |
nacradriver Samba Member
Joined: January 15, 2009 Posts: 760 Location: Ventura, CA
Posted: Fri Oct 31, 2014 6:19 am Post subject: |
I wonder if at the time the Vanagon was being sold in the US, if the speed limit was 65, would VW have gone for a different engine....
At 55 to 63 (100 kph) my van behaves very nice. _________________ Güdrun -1989 Westfalia - 2013 - 2018
Petra - 1985 Vanagon - 1985 to 1991
Zisa - 1974 VW Van "Bus" - 1974 to 1985 |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Fri Oct 31, 2014 6:47 am Post subject: |
I am very curious about this engine. and how it compares to the 2,5 Subaru.
However Im a little worried that the 2,1 block is on the weak side for this much Power. The 2,1 is a tad more vulnerable to Rod bearing wear and failure than the 1,9 is. Remember that all the major Dimensions of this engine is taken from the Type 1 Air cooled engine, that had a displacement of 1,2-1,6.
I see the need for something more powerful than the standard wbx, especially in its detoxed cat Version, and even without cat, it never produced more than 112 hp in its high compression Version. Which by the way require 98 octane.
I also fully understand the want for something original looking, and I respect those who do not want a Japanese engine in their Vanagon.
On the other hand, the Subaru 2,5 is so readily available, relatively inexpensive and easily adaptable, that I do not really see the need for this 2,7 wbx. _________________ 1991 VW Multivan syncro 1,9 TD |
SL12572 Samba Member
Joined: April 13, 2011 Posts: 270 Location: Washington
Posted: Fri Oct 31, 2014 9:59 am Post subject: |
OddN,
The 2.1 block is in fact very robust. The rod bearing issue is addressed by either using 1.9 rods, I-beam rods, or arb studs. These engines can handle plenty of horse power.
While I think the Subaru conversion and pretty much every other engine conversion offered is great, I still believe the WBX is a great engine. Mine had over 220k original miles before being pulled out and was still going strong! It's a simple engine, running a gear driven cam. Using modern technology, such as waterless coolant, and upgraded sealants, these engines can last a very long time with upgraded power.
I'm excited to see what Go Westy comes up with on this new engine and new engine management system....Although pricing may be a big factor! |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Fri Oct 31, 2014 10:00 am Post subject: |
nacradriver wrote: |
At 55 to 63 (100 kph) my van behaves very nice. |
I doubt that the speed limit in one country influenced the German designers very much.
But I do agree that 55 to 63 is the sweet spot - I cruise at 60-62. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Fri Oct 31, 2014 10:12 am Post subject: |
Maybe not a different engine, but a different transmission. In europe the 2.1 vans were typically equipped with a 5 speed that dropped over 400 rpms at cruising speed. VW made the choice to send ours with the 4 speed because the speed limit was so low and the 4 speed was easier to drive around town. The vans would have been better with the 5 speed, though, in terms of effortless cruising on the highway.
Dave |
imtb Samba Member
Posted: Fri Oct 31, 2014 11:38 am Post subject: |
Mine like to curise about 59 mph is the sweet spot.
A 5 speed would be nice on the highway and downshifting to 4th for hills would ok. |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Fri Oct 31, 2014 3:57 pm Post subject: |
While I would agree with the possible problems raised by the thin cylinder walls of the 2.5s, I suspect that faulty FI systems contributed to a lot of the failures. Keep in mind, when GW was testing out their 2.5s they did it on their own rigs and rigs that they maintained for others that they new had good FI systems in them. Put a 2.5 in a van with a bad injector or fuel pressure or some other modest FI problem that is not obvious and causes a bit of a lean mix and you are bound to have problems. I bet if they ran the 2.5s with the new FI system from the beginning, they would have had a lot fewer problems. Frankly, I think the stock looking new FI system with the knock sensor is the better development. 2.7lt... meh..., I'm not going to line up for one. I hope it works out, but I'm with the smaller size with a turbo crowd.
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
morymob Samba Member
Posted: Fri Oct 31, 2014 10:01 pm Post subject: |
Their engine sounds good. And one with good pwr to be able to cruise up 'that' long hill , great. We still have that 'mechanical 'fuse' to contend with, the trans. Originally on my 1st I planned togo with a 3.8 v6, even rebuilt eng & got adptor kit from kennedy until I got educated on the trans. Kept all,5, orig, at this point in time probably will just end up with the stock westy, my 2cts |
Robw_z Samba Member
Posted: Sat Nov 01, 2014 1:52 pm Post subject: |
For tin top guys like me I kinda wish they'd just make a "humble" high compression 2.2 with knock sensing ignition. A good economy engine(no need for premium fuel and better fuel mileage than a 2.1 in theory).
-Rob |
greggearhead Samba Member
Joined: June 20, 2004 Posts: 563 Location: Colorado Springs, CO
keithwwalker Samba Member
Posted: Tue Jan 06, 2015 3:47 pm Post subject: |
I agree to an extent. I have a worn 1.9 and am looking for the next 10+ years. The basic engine architecture has served me well over the last 10 years, but the ancillaries are the Achilles tendon of the whole design.
My concerns with a rebuilt/improved engine are:
Breakerless ignition - I am sick of the cap and rotor
Eliminate the air flow meter with something modern like hot wire sensor
Eliminate the air flow meter's problem prone sensor
Eliminate the crankcase ventilator's influence on the idle speed control
Eliminate the throttle position switches with a non-contact type of sensing (they look like they could break if you look at them wrong)
These are the issues that are a concern come emissions test time, regardless of whether an engine is new or old.
GW seems to have their ECU/ignition/throttle body kit slated for summer 2015. I am still trying to come to terms with the cost...
Robw_z wrote: |
-Rob |
tjet Samba Member
Posted: Tue Jan 06, 2015 4:52 pm Post subject: |
I'm looking at this kit, mainly because most of the EFI on my '87 2.1 wbx needs replacing....
http://www.sdsefi.com/ |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Tue Jan 06, 2015 5:52 pm Post subject: |
Big car maker never passed 2.5L for 4 cyl in mass produce car.
there is a simple reason, it's called physic. Stoke VS bore VS weight VS inertia.
I know there are in Cali but they should look for some kind of engine conversion instead of enlarging the stock case. No matter what the wall thickness is. It's still a 1980 design FI
In my shop I have replace 2 of their engine that where less then 2 yo. One being a 2.5L
Plain stupid.
Trust me I respect them and deal with them but going 2700 cc is.. no, just no.
Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
