advinnie Samba Member
Joined: November 18, 2011 Posts: 1389 Location: oxfordshire
Posted: Mon Oct 27, 2014 11:24 am Post subject: Do I need a balanced cooling fan at 6500rpm? |
Hi all im building a 2188cc motor capable of hitting 6500rpm so should I be looking at fitting a balanced cooling fan or not? If not at what rpm can the stock fan take?
Cheers |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Mon Oct 27, 2014 11:51 am Post subject: |
Get welded balanced fan now....cheap insurance. |
Howard 111 Samba Member
Posted: Mon Oct 27, 2014 12:19 pm Post subject: |
Agree. I never go above 6000rpm with my turbo engine, but run a balanced, welded fan. Some stock fans are so poorly built, I would worry all the time about using a stock fan. Like rs58rag said, it's cheap insurance. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
Hotrodvw Samba Member
Posted: Mon Oct 27, 2014 12:25 pm Post subject: |
I ran my OEM unbalanced, un-welded fan over 7k on the dyno accidentally...and got lucky. I won't do it again LOL
Now have the OEM fan welded.....peace of mind is worth a lot IMO. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Posted: Mon Oct 27, 2014 12:47 pm Post subject: |
Thanks for the replys all i think a welded balanced fan is now on my shopping list |
Posted: Mon Oct 27, 2014 3:11 pm Post subject: |
it depends on your fan belt. If you run a sticky and tight belt, yes get a welded fan. If you run a slickery belt a little looser, there is no need since the belt slips around 4k RPM crank speed. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Mon Oct 27, 2014 3:15 pm Post subject: |
Stock belts slip at 4000rpm crank speed shit j was driving at 4800rpm (90mph) for over 30 minutes im surprise my engine didn't over heat with the cooling fan not running at the right speed. |
Posted: Mon Oct 27, 2014 3:28 pm Post subject: |
starts slipping. Doesn't slip completely! But the fan doesn't go any faster even though the engine does. This is not the case for "grippy" belts or Serp systems though, they are far more likely to blow up fans. _________________ It's just advice, do whatever you want with it!
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Mon Oct 27, 2014 4:58 pm Post subject: |
advinnie wrote: |
next time stop and see how hot the pulleys are!! smokin. But the belts still last a long time somehow, unless your pulleys are out of line.
I like to use the slightly smaller "1500" size fan.
Still cools about the same maybe better at 4000 rpm, I think the belt just slips less. Stronger too.
Balanced?? hopefully. All the OE ones were balanced (they have little weights welded on) but some new ones aren't, and some are wobbly too, I'd try to find a good one and have it tig'd. |
mark tucker Samba Member
Posted: Mon Oct 27, 2014 8:46 pm Post subject: |
Im not sure about thatmuch belt slip, they last awefull long for a belt slipping that much. Ive shreaded lotsa belts on v8 stuff & slurpintime belts on superchargers oh so many times. but you should have a balanced fan. I have 1 and need 2......amoung other things. |
rrcade Samba Member
Joined: May 29, 2010 Posts: 735 Location: WI 1962 Bug 2276
Posted: Mon Oct 27, 2014 9:15 pm Post subject: |
Anybody got pictures of the aftermath of an exploded fan? |
jeff68 Samba Member
Joined: November 02, 2007 Posts: 298 Location: Sarasota, Florida
Posted: Tue Oct 28, 2014 7:03 am Post subject: |
Keep in mind that a hi-performance vw engine accelerates (reaches rpm) much faster than a stock engine (which the fan was designed for). So in other words it's not only peak rpm that makes a welded fan a very good idea, it's the increased forces put on the fan when accelerating the fan from low to high rpm. Even with a slipping belt (if it doesn't slip a lot) the fan is accelerating faster. That's why many fan failures (fans coming apart) happen when the engine is revving from low to high rpm. I apologize if you all knew this already, I just didn't see it mentioned is all.
IMO any Hi performance vw engine (one that revs faster and has a higher rpm potential than stock) should have a welded and balanced fan. |
bluebus86 Banned
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Tue Oct 28, 2014 9:36 am Post subject: |
Id say 6k is a good number as long as its a V belt and OEM fan (I've seen pretty crappy aftermarket fans)
I rev to 6k often but I run my belt pretty loose, never broke a belt or fan _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Tue Oct 28, 2014 2:44 pm Post subject: |
Back a few months ago I was drag racing my Dunebuggy. I had a Bugpack welded and Balanced fan. I hit 7000 RPM with the stock sized pulley and fan belt. I felt a serious vibration and immediately shut it off. None of the blades came loose but they were all distorted so bad I couldn't get it out of the fan shroud without cutting it out. It damaged some of the vanes in my 36 HP doghouse shroud.
I run a Bugpack welded & balanced fan in my race car with a power pulley turning 7000 RPM's and never had any problems. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Tue Oct 28, 2014 5:43 pm Post subject: |
The increasing horsepower draw from the fan means the fan belt begins slipping at around 4000rpm.
It simply can't transmit any more power. So spinning the engine faster doesn't actually spin the fan any faster. It is a 'self-preserving' system.. and the reason why a VW's maximum cruising speed is 4000rpm... that is the point of max air flow and hence cooling ability of the fan/system
Do NOT fit a serpentine belt. not. ever.
I have had one fan 'bend' but that was when a foreign object (tree leaf IIRC) entered it and unbalanced it.
I use 7500rpm in motorsport/drags/etc with a standard DP fan... inspected and driven from a power pulley, which of course slows the fan down a little. This has survived hundreds of runs but if it were to fail again, I would of course investigate a 'race prepped' fan as a replacement |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2237 Location: Medford, OR
Posted: Wed Oct 29, 2014 9:00 pm Post subject: |
This was my experience with a stock fan
I've got a fan welded and balanced by racinjason. Haven't blown it up yet. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Posted: Thu Oct 30, 2014 1:26 am Post subject: |
Nice you got lucky |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Thu Oct 30, 2014 7:42 am Post subject: |
I ran a stock fan in my 2276, hit 6500 a few times. It didn't come apart but the pucker factor ate the drivers seat up I got a welded and balanced fan for extra insurance and my drivers seat is OK now _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Thu Oct 30, 2014 11:51 am Post subject: |
Damn RacerDave, so you twisted up a welded fan, wow, first time I have heard of that to be honest, and it was welded..... Wonder how often it occurs?
All that got torn up was the shroud, guess you were guess you had to trailor that car that night home,lol... RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
