Malokin Martin Samba Member
Posted: Mon Oct 27, 2014 1:52 pm Post subject: Roof rack weight limit? |
I've done several searches here and elsewhere. Maybe I'm not using the right search terms.
Does anyone know what a split bus weight limit would be for a rack mounted to the drip rails? Specifically a 1962 double cab with 3 leg rack but realistically ANY overall advised roof weight limit from the factory.
I saw 220lbs somewhere but wasn't sure
Thanks in advance. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Mon Oct 27, 2014 3:20 pm Post subject: |
Would depend on the manufacture of the rack. Anywhere from 100 to 300 Lbs.. _________________ In Stereo, Where Available! |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Oct 27, 2014 4:11 pm Post subject: |
Let me go check my ZVW rack sticker on my 6' VWoA rack, be right back...
OK, I'm back, and as stated earlier- it's is marked 220lbs. I'm sure that really means up to around 350 evenly distributed, as VW notoriously underrated their capacities for such things. _________________
EverettB wrote: |
FU#5 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Oct 27, 2014 5:07 pm Post subject: |
Hmmm....., I can't see anything in the splitty manuals but the early bay ones say 165 lbs for the DC under roof capacity (220 for bus), the drip rails are really similar so I'll bet that's the same for a split. They say "evenly distributed" so more legs on the rack is better, I doubt it's the strength of the drip rails that are the issue as much as handling unless you also have a heavy load in the back to balance things out. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ezcamper Samba Member
Joined: January 10, 2001 Posts: 897 Location: Atlantic Beach, FL
Posted: Mon Oct 27, 2014 6:05 pm Post subject: |
350-400 lbs
about the same... maybe more.
_________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks |
Posted: Mon Oct 27, 2014 8:36 pm Post subject: |
Really appreciate the feedback. I was looking into one of those rooftop tents and was curious if it could handle the tent +2 adults (on a DC). It would be a Yakima rack, so the rack really isn't the problem. Its more of a matter if the rails can handle it.
I'm just a bit too long for the bed to lay down and it would be fun to have it up there for the kids.
I wonder if there was a way to tell if the rails were overstressed |
velvetgreen Samba Member
Posted: Mon Oct 27, 2014 11:03 pm Post subject: |
on a related noted I know that HWE racks much like the ones that EZCamper makes originally came with a weight load sticker. IS anyone repopping them? |
Sdmjake Samba Member
Joined: May 01, 2012 Posts: 124 Location: Sandy Springs, GA
Posted: Tue Oct 28, 2014 6:18 am Post subject: |
I have seen racks that doubled as an observation deck. Not sure how much they hold but seems like you could put a tent on one. Here's a link to a guy that makes repro sundial/caravelle decks...pretty sweet.
http://customautoracks.com/vwracks.htm |
mtb7001 Samba Member
Joined: February 11, 2009 Posts: 899 Location: Meridian Idaho
Posted: Tue Oct 28, 2014 8:04 am Post subject: |
If your'e using 1A raingutter towers just use MORE sets. Mount 4 bars on 4 towers. Four contact points, each capable of holding 200-300lbs easily. It would be interesting to see an actual test on how much it would take for a rail to fail. _________________ 63 15 window deluxe Turkis walk through 1500
"comfort the afflicted, afflict the comfortable" |
hitest Samba Member
Posted: Tue Oct 28, 2014 2:56 pm Post subject: |
mtb7001 wrote: |
If your'e using 1A raingutter towers just use MORE sets. Mount 4 bars on 4 towers. Four contact points, each capable of holding 200-300lbs easily. It would be interesting to see an actual test on how much it would take for a rail to fail. |
Ding Ding Ding! The perfect answer. On my Vanagon, I simply ran three 1A bars- I could stack two daycare centers up there and had enough capacity for a spare nursing home- all full of diapers.
Really though, the 1A towers distribute the weight with their wide feet on the gutters better than any VW rack. More importantly, and mtb7001 knows this one... the rack's clips handle the PULL against the gutters very well. It is this pulling force when on the highway that cause more stress to roof racks and gutters than the weight ON the gutters. If you catch my drift. _________________
EverettB wrote: |
FU#5 |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Tue Oct 28, 2014 4:35 pm Post subject: |
Malokin Martin wrote: |
You mean like this?-
I have camped with two kids and 1.75 adults (my wife & I). I wouldn't recommend that many people up there. Not because of the drip rails. But because it turns into a Monkey House and you can die if you fall out!
I don't have pics, but I made a rack that would hold the Camp'otel in the bed at the same height as an HWE halfrack. I never camped in it that way, but it was a better solution than so high on the roof. Easier to get in and out of and a slightly lower profile. My plan was to mount a piece of plywood in the rack and fab up a cover for it so we could sit up there. I called it "The PORCHE".
There was plenty of storage under the camper and up on the rack. Ialso made chains to hold the gates level when disconnected for a handy place to cook, store coolers, etc. I would be camping in it like a Boss if the economy hadn't kicked my ass.
In the pic you can one of the VW bus jacks that I used in the jackpoints to both level up the bus and stabilize it. That worked great.
And to answer the OP's question, a rack that positions the legs over the A & B pillars and the posts between the side windows will hold several 100 pounds. I don't think it is the bus structure that will limit you. It will most likely be the rack bending. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Tue Oct 28, 2014 7:39 pm Post subject: |
Thanks folks! Great info all around. Really appreciate it. |
