Using Okrasa heads with thermostat
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Mon Oct 27, 2014 11:41 pm    Post subject: Using Okrasa heads with thermostat Reply with quote
I understand that I'll need to modify my repro Okrasa heads if I want to use a thermostat. I would imagine that a drill could be used to cut a hole though the fins, but I'm concerned that I would break some/all the fins in the process. Has anyone modified their Okrasa heads to work with the stock thermostat?
Cheers,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
Stuart Maingot
Stuart Maingot is offline
PostPosted: Fri Oct 31, 2014 3:06 pm    Post subject: Reply with quote
Use a milling tool and cut from top down. Avoid cutting on the side of each fin and it should be fine.
Stocknazi
Stocknazi is offline
PostPosted: Tue Nov 18, 2014 8:24 am    Post subject: Reply with quote
That would have been a good improvment to the og design imo.
WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson
