clubtreb Samba Member
Joined: June 18, 2007 Posts: 554 Location: miami beach
Posted: Tue Oct 28, 2014 12:42 pm Post subject: whats your thoughts on putting dual single barrel carbs on |
whats your thoughts on putting dual single barrel carbs on a stock 1500? It is a single port with 12 volts. 75 amp alt,009,. My parts guy was trying to talk me out of them.i would down the road replace the heads ,pistons, etc. |
Danwvw Samba Member
Posted: Tue Oct 28, 2014 12:49 pm Post subject: |
I would think they would work fine because it's already a single port! Does it have much cam? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Tue Oct 28, 2014 12:52 pm Post subject: |
Cam i would think to be stock. |
GTV Samba Member
Posted: Tue Oct 28, 2014 1:21 pm Post subject: Re: whats your thoughts on putting dual single barrel carbs |
clubtreb wrote: |
Then wait until then. _________________ EMPI Power Rules! |
Posted: Tue Oct 28, 2014 1:41 pm Post subject: |
Ok this is the thing. My gen died. So got a alt. Got every nut and screw off but the bottom right side of backing plate on fan shroud. Which is a flat head screw driver type bolt that is round so i cant get anything onto it the intake is in the way.so was thinking cutting off the manifold and upgrade a little. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Oct 28, 2014 1:44 pm Post subject: |
Soak in Blaster overnight and grab with a small vice grips- save the manifold
Whats your hurry? _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Tue Oct 28, 2014 1:58 pm Post subject: |
Is the motor in or out? |
Posted: Tue Oct 28, 2014 2:18 pm Post subject: |
Yes the motor is in. I have the fan nut off in back. No. Problem. And the rush is that it'smy daily ddriver. Missing work. Spending rent. |
GTV Samba Member
Posted: Tue Oct 28, 2014 2:20 pm Post subject: |
Just get the screw out. You won't be saving time upgrading to duals. _________________ EMPI Power Rules! |
Posted: Tue Oct 28, 2014 2:27 pm Post subject: |
Also i tried the needle nose vice grips but the bolt in there is a rounded off type and the metal lip on the fan cover sticks out. Making it hard to get a good bite on it. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Oct 28, 2014 2:34 pm Post subject: |
If you're in a daily driven hurry, switching to dual carbs and trying to tune them on the side of the road does not save you work release time. _________________
EverettB wrote: |
FU#5 |
Posted: Tue Oct 28, 2014 2:36 pm Post subject: |
I thought off getting the screw out. Im going to have to cut the manifold to get to it. I geuss my question is has running these carbs bad. I will upgrade too bigger heads and pistons. Down the road. |
Posted: Tue Oct 28, 2014 2:41 pm Post subject: |
Ok so i would hate to cut my manifold, just to buy the same thing. What would be a upgrade. |
Posted: Tue Oct 28, 2014 2:43 pm Post subject: |
Posted: Tue Oct 28, 2014 2:50 pm Post subject: |
BDSBSS23 Samba Member
Joined: January 03, 2008 Posts: 1817 Location: Colorado
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8206 Location: San Dimas
Posted: Tue Oct 28, 2014 6:19 pm Post subject: |
I will try the side bolts.just want too upgrade. And dont want to buy the same stuff i had. |
Posted: Tue Oct 28, 2014 6:24 pm Post subject: |
Carb kit was off samba at carcraft i th8nk r8verside cali |
Posted: Tue Oct 28, 2014 6:39 pm Post subject: |
So im thinking nobody has had any luck with this set up? I had a set back in the 80's.... thought it ran great.. but then again it was the 80's and don't remember much. Button south? Anyone? No keep it on the topic..
Button was cool though. |
