clubtreb Samba Member
Joined: June 18, 2007 Posts: 554 Location: miami beach
Posted: Tue Oct 28, 2014 7:10 pm Post subject: |
So im thinking nobody has had any luck with this set up? I had a set back in the 80's.... thought it ran great.. but then again it was the 80's and don't remember much. Button south? Anyone? No keep it on the topic..
Button was cool though. |
GTV Samba Member
Posted: Tue Oct 28, 2014 7:56 pm Post subject: |
I have no idea what you're talking about. _________________ EMPI Power Rules! |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Tue Oct 28, 2014 11:04 pm Post subject: |
Okay, I'll jump in here. I had a set of Weber ICTs on my '58 single cab in the 90s. Stock profile cam and a 009, and they ran very well. They had no choke so there was lots of tap dancing on the throttle for the first while on some colder mornings, but ran well after warmed up.
They are easy to balance and stay set up for ever.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
volksaddict Samba Member
Posted: Wed Oct 29, 2014 6:04 am Post subject: |
Only 4 bolts and the motor is out, hit the screw with a chisel to start it and it's fixed.
Then you'll know how to pull the motor when you do your upgrades. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Wed Oct 29, 2014 6:34 am Post subject: |
volksaddict wrote: |
Yes, save time, pull engine, fix properly. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Wed Oct 29, 2014 7:37 am Post subject: |
j.pickens wrote: |
Yes, save time, pull engine, fix properly. |
Another vote for this... It'll take you longer to cut through the manifold and swap carbs and all that nonsense than it will to just pull the motor and fix it properly. _________________ -Andrew |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Wed Oct 29, 2014 8:41 am Post subject: |
Andrew wrote: |
j.pickens wrote: |
Another vote for this... It'll take you longer to cut through the manifold and swap carbs and all that nonsense than it will to just pull the motor and fix it properly. |
+ 120000
Just pull the motor. You could be driving by now if you did. |
Malokin Martin Samba Member
Posted: Wed Oct 29, 2014 9:15 am Post subject: |
^above |
Posted: Wed Oct 29, 2014 7:03 pm Post subject: |
Even with the motor . Ive pulled a hundred. It still won't help me getting to the screw on the bottom right of fan plate.with manifold in front. |
GTV Samba Member
Posted: Wed Oct 29, 2014 9:09 pm Post subject: |
Yes it will. It will allow you to easily lift the fanshroud up and access the screw. And while you're there, swap the backing plate screws for hex bolts, that's what VW intended to be there, so you don't have to get to it from straight on. _________________ EMPI Power Rules! |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Wed Oct 29, 2014 9:12 pm Post subject: |
Being able to get at that bolt from all angles HAS to be easier than from the one torturous angle thru the engine lid. |
DannoT Samba Member
Joined: September 15, 2007 Posts: 249 Location: Up where the air is thin
Posted: Wed Oct 29, 2014 10:24 pm Post subject: |
Been a while since I worked on a single port but why not remove carb and then remove the 4 nuts holding the manifold on, then when thats out of the way you can get to your fan shroud screw. Or get a really long drill bit and drill right through the manifold, and then through the screw, afterwards duct tape the manifold back up. it's fool proof |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Thu Oct 30, 2014 6:37 pm Post subject: |
Have you tried a magnetic screw driver TIP and a small box wrench or socket? _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
