low_67 Samba Member
Joined: October 08, 2014 Posts: 52 Location: Virginia Beach
Posted: Tue Oct 28, 2014 4:21 pm Post subject: 2nd time running out of gas. fuel gauge or sending unit? |
Which should I replace first? Gauge reads around 1/4 remaining when I sputter to a halt. Looks to be a little fuel in tank though. But added a gallon from my jerry can and got it going again. So where should I start? I'd like an accurate reading! |
grandpa pete Samba Member
glutamodo The Android
Joined: July 13, 2004 Posts: 26311 Location: Douglas, WY
Posted: Tue Oct 28, 2014 4:51 pm Post subject: |
Well, if it's a 67 like his user name says, sounds like typical issues with mechanical fuel gauges... (something I discussed ad nauseum here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=231562
But first, have you checked the adjustment on your setup? (assuming it's mechanical)
low_67 Samba Member
Posted: Tue Oct 28, 2014 7:04 pm Post subject: |
67
low_67 Samba Member
Posted: Tue Oct 28, 2014 7:28 pm Post subject: |
glutamodo wrote: |
Thanks. I'll give the adjustment a shot first. |
low_67 Samba Member
Posted: Tue Oct 28, 2014 8:21 pm Post subject: |
Did the adjustment. Broke the needle off the gauge :/ |
Posted: Tue Oct 28, 2014 9:04 pm Post subject: |
I think you mean:
That sucks - some gauges have a bottom peg, some don't... and that plastic does get brittle with age. I've broken one off before. |
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Wed Oct 29, 2014 4:23 am Post subject: |
I've never met a truely accurate fuel gauge... the trick that I've used for years is to write the milage down in the corner of the windshield with a china marker whenever I fill the tank. It's then just a matter of setting a milage limit to fill up again, based on how many gallons I'd like to have remaining and the milage that vehicle normally gets. For my '60 (which has no gauge to begin with), I normally get an honest 30+mpg and prefer to have a 2 gallon reserve, so I fill up again after travelling 260 miles from the number written on the windshield. Did the same method in my '68 and my '72, even in my '84 Vanagon back in the day. _________________ 1960 Ragtop w/Semaphores "Inga" |
low_67 Samba Member
Posted: Wed Oct 29, 2014 8:01 am Post subject: |
Anyone know if the fuel gauge can be disassembled so I can get at the needle? A little super glue would save me $50 |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Wed Oct 29, 2014 8:22 am Post subject: |
I used to use one of those manual trip odometer boxes stuck to the dash for the same reason.
I also did the calibration so I knew when I had 1 gallon left. Accuracy when nearly full is not usually important, but those last few drops are!
Eventually I put in a round electric gauge and sender from a later Ghia. Those seem to be more accurate. |
Posted: Wed Oct 29, 2014 8:33 am Post subject: |
low_67 wrote: |
Yeah, you can take the lens off if you want to try that. I remember fixing one I broke by epoxying a toothpick or something like that in place of the needle and painting it white. Do note that the chrome trim is a bit fragile where it is crimped over the gauge housing. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Wed Oct 29, 2014 3:13 pm Post subject: |
What.. nobodys heard of the swerve and watch for the gauge jump method...
If you want accurate... good luck.....
Its really pretty simple to me..... just dont run the fuel that low..
I think the old reserve tap was the best CYA.....
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
KTPhil Samba Member
Posted: Wed Oct 29, 2014 5:04 pm Post subject: |
VOLKSWAGNUT wrote: |
Close cousin to the "rock left and right at the stoplight and watch the gauge" method I often used. |
low_67 Samba Member
Posted: Wed Oct 29, 2014 5:35 pm Post subject: |
You sound like my wife.
Alright alright. Got the needle glued back on and adjusted per instructions above. Good to go. I don't do the mpg method because my speedo cable broke last week. Yup. |
Posted: Wed Oct 29, 2014 6:03 pm Post subject: |
I must say..and admit...... I've always "tested" my out of fuel spot in my cars....... Not fun... so try to avoid it...
I've got a story of running out of gas in a 67 Cougar twice on the same road trip ... but my brother just so happened to be driving both times ... so not my fault... but love to give him shit bout it....
Broken speedo... and inaccurate fuel gauge.... you need a fuel reserve tap, and an extra can of fuel, or.... simply fix the damn thing,...
low_67 Samba Member
Posted: Wed Oct 29, 2014 6:24 pm Post subject: |
Well I think the gas gauge is good now. And just took out the spare tire, since it won't even be used because the car is too low, and replaced it with a 1 gallon jerry can. Good for me or anyone else that gets stranded. |
