gas tank resto
oldbug
oldbug is offline
PostPosted: Thu Jan 22, 2004 12:31 pm    Post subject: gas tank resto Reply with quote
I am restoring a 57 gas tank. I have heard of a cleaning method that
radiator shops can do to the inside of the tank. does anyone know what
that is called
Thanks Ed
UncleBob
Grease Midget
UncleBob is offline
PostPosted: Thu Jan 22, 2004 1:04 pm    Post subject: Reply with quote
Boiling.
OG JHC
don't worry, the ciggaret is fake.
gophercat
gophercat is offline
PostPosted: Thu Jan 22, 2004 3:12 pm    Post subject: Reply with quote
You can also do it yourself with a resto kit if you want to go that way as well. Usually costs about $45-50 dollars for the kit.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jan 22, 2004 3:31 pm    Post subject: Reply with quote
Here's how i did the tank in my 74.
http://www.glenn-ring.com/tech/gas_tank_resto.htm
Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Thu Jan 22, 2004 5:07 pm    Post subject: Reply with quote
Quart of muriatic acid in a gallon of water, and toss in a length of heavy old chain. Seal openings, wear skin and eye protection, and shake. Drink beer, shake, and repeat. Dump onto bitchy old neighbor's lawn in middle of night. Rinse and coat with rust converter like Picklex, and then the POR protective coating.
oldbug
oldbug is offline
PostPosted: Sun Jan 25, 2004 12:56 pm    Post subject: Reply with quote
Thanks for all the help guys think i will try the boiling and por15
ed
FL_VERT
FL_VERT is offline
PostPosted: Sun Jan 25, 2004 3:27 pm    Post subject: Reply with quote
I just looked at the kit.... I Just bought a new tank instead and a whole lot less work on my part..
$70.00 Radiator Shop
$65.00+ Por 15 kit plus shipping
$80.00 New Tank
If I was to restore a tank I would have it chemically dipped, Galavanized, powdercoated/or Painted, Sealed inside.......
Saggs
Saggs is offline
PostPosted: Mon Jan 26, 2004 8:32 am    Post subject: Reply with quote
where do we dump the muriatic concoction if we don't have a bitchy old neighbor near by? Is it good for the finless browns in the storm drains? Is the POR 15 coating inside a permanent fix?
Major Woody
Samba Enigma
PostPosted: Mon Jan 26, 2004 10:46 am    Post subject: Reply with quote
Dump it into a plastic pail. Neutralize it by stirring in a box of baking soda. Then flush it down the toilet.
Replacement tanks are a good option if they are available. There is no replacement tank available for my car, plus I just like the idea of reusing as much of the original car as possible.
The POR coating (it is not POR-15 which is a rust converter and encapsulator) is advertised as a permanent coating. I have never heard any stories of it failing.
I think the radiator shop trip is unnecessary. Any real man has chain in his garage and a few cans of beer. Just go buy yourself some $5 acid and go for it.
Mr. 010
Glenn is offline
PostPosted: Mon Jan 26, 2004 10:57 am    Post subject: Reply with quote
Before restoring my tank, i purchased a replament tank. The metal was alot thinner, the hose fittings didn't lineup correctly and i didn't like the MADE IN BRAZIL that was stamped into the metal on top.
And after that you should still coat the inside and paint the outside.
I had mine boiled ($30), then powder painted it and finally used the POR Gas Tank Sealant.
It should be good for many years... more than a Brazilian replacement tank.
Glenn
HBB/RW
www.DasVolks.com
Saggs
Saggs is offline
PostPosted: Mon Jan 26, 2004 1:11 pm    Post subject: Reply with quote
thanks for the acid tip, Ive got a crusty old tank in a 56 oval I'm restoring and the $5.00 for chemical and $10.00 for beer is a fun and educational alternative.
6d7vdub
Samba Slacker
6d7vdub is offline
PostPosted: Mon Jan 26, 2004 4:55 pm    Post subject: Reply with quote
There is a pretty informative article on this exact subject in Hot VWs January 04 edition.
Bill
Sadie's Site
http://positivepause.com
spookymulder
Samba Proletariat
Location: I'm either at 95608, 97537 or 94708 only my CPA knows for sure
spookymulder is offline
PostPosted: Tue Jan 27, 2004 8:33 pm    Post subject: Reply with quote
I use a product called Rusteco www.rusteco.com for cleaning the tank. I then use this product called Slushing Compound.available from www.mossmotors.com You pour it in, slush it around and pour out the excess. Let dry for 24 hours and use. It kicks ass, fills little rust pin holes and makes the inside look like brand new.
orangebug60guy
Twin #1
orangebug60guy is offline
PostPosted: Wed Jan 28, 2004 4:54 am    Post subject: Reply with quote
how long do gas tanks last?
66 bus with factory slider!- $50
Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation.
View user's profile Send private message Send e-mail AIM Address MSN Messenger Facebook Gallery Classifieds Feedback
Mr. 010
Glenn is offline
PostPosted: Wed Jan 28, 2004 6:35 am    Post subject: Reply with quote
It depends on how much water is in the gas you buy.
Many rust from the inside out. Others rust due to leaky trunk seals. My 74's rusted in 10 years, but my 57 has the original.
Glenn
HBB/RW
www.DasVolks.com
Major Woody
Samba Enigma
PostPosted: Wed Jan 28, 2004 9:58 am    Post subject: Reply with quote
My 56 has the original. They rust just like anything else made of steel. Tank wasn't too bad--car spent most of its life in California and I think the heat there kept the condensation in the tank down.
