Black Bug Samba Member
Joined: May 24, 2014 Posts: 25 Location: Pennsylvania
Posted: Wed Oct 29, 2014 3:28 pm Post subject: 56 body on a 67 pan?? |
I have a fully customized 67 pan that I need a body for. Will a 56 body bolt right up to the 67 pan? |
Bruce Samba Member
Posted: Wed Oct 29, 2014 5:31 pm Post subject: |
Yep. _________________
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Wed Oct 29, 2014 8:49 pm Post subject: |
What do you mean by "fully customized"? |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Wed Oct 29, 2014 10:54 pm Post subject: |
motofly196 wrote: |
Probably dropped with lots of bling. Rappers will love it
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
Posted: Fri Oct 31, 2014 3:23 am Post subject: |
New pans, shortened beam, hard fuel lines w/ an fittings tig welded to chassis, dual circuit master cylinder w/ reservoir, entire chassis blasted down, smoothed and powdercoated gloss black. I have way too much time/effort/money into this thing to ever think about doing another one, so if the 56 didnt bolt right up, I would have to find one that did. I just had the 67 bead blasted, and found out that it was a highly polished turd. The p/o had so much bondo on the car--- he actually somehow "built" the heater channels out of bondo. So now I have a 67 that I have to send to the recyclers, and a 67 chassis w/o a body. |
Posted: Fri Oct 31, 2014 3:25 am Post subject: |
No bling, though. Not my style... |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sun Nov 02, 2014 12:44 pm Post subject: pans |
...here's a '63 on a '66 pan and the car in front of the '63 is a '55 on a 1965 pan...bolts right on and secures well. There will be a couple of extra securing areas, under the back seat that are not present on the '56, that are on the '67... but no problems.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Sun Nov 02, 2014 4:20 pm Post subject: |
I've noticed that the shock mount in the rear looks different from the 67 to the 56. The 67 looks more "curved "... I haven't had a chance, as yet, to compare them side by side. Is that the difference you are referring to? |
Posted: Sun Nov 02, 2014 4:22 pm Post subject: |
Also, I had the z-bar for the 67 rebuilt/ powdercoated. I am guessing it simply isn't used for the 56? |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Mon Nov 10, 2014 8:47 am Post subject: |
About 25 years ago I mounted a '56 oval body onto a nice, solid '66 frame. The only "discrepancy" I can remember was that a few fasteners beneath the rear seat were not accounted for- either there was a hole for one on the body but no matching attachment point on the pan, or vice-versa. I'm talking about either one of the 8mm body bolts that go on the edge of the floorpan, or one of the larger 10mm ones that are found in pairs toward the outer rear corner of the rear seat cushion and go into the frame casting above the torsion bar housing. Either way, using only the one fastener per side of the car, the body fit well. I sold it a few years later.
I'm reasonably sure that the '66 pan would be the same as your '67 as to the attachment points for a body.
Then use the 2-chamber brake fluid resevoir from the '67 and mount it on the same location as the metal single reservoir on the oval's body (shelf behind the spare tire). |
