73ratkafer Samba Member
Joined: September 17, 2014 Posts: 12 Location: Clifford, PA
Posted: Thu Oct 30, 2014 8:11 am Post subject: My 73 Dually Rat Rod Beetle "Death Trap" Build |
Hey everyone!! I'll start off by saying this is my first classic VW and so far I'm having a blast building this car. I'm currently working on a 1973 SB that I'm making into a rat rod and yes those are dual wheels on the rear : ). Here's some pics of what I've done so far. I plan on pulling the body off soon to patch it up over the winter.
Here's a roof rack I built for the car out of an old hand truck. The front mounts are made to look like skeleton hands holding the rack to the car.
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Thu Oct 30, 2014 9:59 am Post subject: |
Looking forward to the build, great theme _________________ If I knew what I was doing; I wouldn't be building a buggy! |
WD-40 Samba Member
Posted: Thu Oct 30, 2014 9:57 pm Post subject: |
Just for grins, how much does a pair of your dual rear wheels/tires weigh? The handling should be... interesting.
Are you starting with a running/driving car? _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
Posted: Sat Nov 01, 2014 6:56 pm Post subject: |
WD-40 wrote: |
Are you starting with a running/driving car? |
They aren't the lightest wheels haha. The car is not running and driving at the moment. When I pull the body off, I'm pulling the engine too so that I can get it running on the bench and maybe build it up a little. I don't know how those 45 horses are going to turn those duals. |
Brian Samba Moderator
Posted: Tue Nov 04, 2014 5:08 pm Post subject: |
I'm very interested in how you're going to make dually wheels. I kinda want to do that for running in the sand.
Like these but much bigger:
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Tue Nov 04, 2014 6:31 pm Post subject: |
Brian wrote: |
Well, they are actual dual wheels I pulled off of an old Toyota camper in the junkyard. I need to have adapters made for it but, other than that they should be fine. |
TC/TeamEvil Samba Member
Posted: Thu Nov 06, 2014 4:48 pm Post subject: |
What are you planning to do with the Super Beetle front end? Frame graft, something custom? Certainly can't leave it as McPherson struts. |
Posted: Fri Nov 07, 2014 12:36 pm Post subject: |
TC/TeamEvil wrote: |
I'm not sure yet on that. Gonna get the body straightened out this winter and then go from there. The floor pans and frame head are badly rotted so I have to replace the chassis anyway. |
morymob Samba Member
Posted: Wed Dec 10, 2014 2:59 pm Post subject: |
After someone gets ripped by those vent(?) Looking rusty teeth things........... |
Posted: Tue Feb 03, 2015 7:57 pm Post subject: |
I'm in some dire need of advice here. I have the body off of the bug and plan on setting her on a small truck frame. I am having a lot of troubling with the doors sagging horribly with the heater channels cut out and no matter what I do, they refuse to cooperate. Any advice? I need to get the door situation fixed before I can put it on a frame. |
Posted: Tue Feb 03, 2015 7:58 pm Post subject: |
morymob wrote: |
I actually ground down the end of each tooth to prevent any danger. |
Petfisheric Samba Member
Joined: November 27, 2014 Posts: 121 Location: Knoxville, TN
Posted: Tue Mar 10, 2015 10:55 am Post subject: |
Don't know if you fixed the door sag problem but you will have to tie the bottoms of the A and B pillors together again like the heater channel was doing. |
FullFender Samba Member
Posted: Wed Jun 03, 2015 8:36 pm Post subject: |
Any update? I am very intrigued by this build. I am currently working on a 67' beetle street rod and this is giving me some ideas!
Thanks, Triston |
Manfred58sc Samba Member
Posted: Mon Jun 22, 2015 1:37 pm Post subject: |
Lookin' good..here is some inspiration (hopefully anyway). SB makes a cool rat in book. _________________ Fat chick owner/operator |
