DHMaher Samba Member
Joined: November 16, 2009 Posts: 787 Location: Portland, Oregon
Posted: Thu Oct 30, 2014 9:38 am Post subject: oil pouring out of valve |
Last month I bought a spare engine to fix up. The biggest problem I have is oil leaking from the valve cover. When I went to replace the gasket, I turned the engine over by hand and oil came streaming out of one of the valves. This didn't seem normal... Replaced the gasket and oil is still leaking. Any thoughts on why so much came out? I will investigate the leaky gasket later.
Thanks, _________________ Daniel
"POs, you gotta love them, because killing them is illegal." -Unknown Samba Member
1967 Beetle - Java Green
See my ads |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Thu Oct 30, 2014 9:55 am Post subject: |
:idea Inside the engine case will only contain so much oil thus if over filled will come out the push tubes in to the valve cover and LEAK or dump when the cover is removed...assuming the engine is in/out of the car and NOT running.
If running oil would exit via other places due to possible internal compression issues......just too many variables w/o knowing more. |
my59 Samba Member
Joined: August 13, 2003 Posts: 3781 Location: connecting the dots
Posted: Thu Oct 30, 2014 3:10 pm Post subject: |
You said it was to fix up.
If oil came out a valve now you know why... _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Thu Oct 30, 2014 3:39 pm Post subject: |
my59 wrote: |
If oil came out a valve now you know why... |
You got that right! Now any idea why? Will check the oil level this evening... _________________ Daniel
See my ads |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Thu Oct 30, 2014 6:28 pm Post subject: |
I think you mean out of one of the valve stems? If so, it would have to come out of the cylinder itself and past the valve heads.
Could it be that the engine was in storage and someone squirted oil in the cylinders to keep them lubed? There would have had to have been quite a lot in there.
Or, was the engine shipped or laid on one side or the other at a steep angle? What is the oil level in the sump?
Not at all typical, so it may take some tear down for diagnosis. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
