ddare Samba Member
Joined: January 10, 2005 Posts: 583 Location: Cypress, CA
Posted: Thu Oct 30, 2014 10:12 am Post subject: Stripped exhaust stud - options? |
I was driving my VW to work this morning and heard exhaust leak, so I pulled over and noticed the gasket had blown out. I had a couple spare gaskets at home so I thought no problem, pull the exhaust, replace the gaskets and I'm good to go. Unfortunately, one of the nuts was turning and not getting tight. I pulled the exhaust back off and it's apparent one of the studs is stripped about half way down. Can I dremel a slot into the stud, remove it with a screwdriver and replace the stud? Or do I have to use a time sert on the existing stud? Can I leave the head in place, or do I need to remove it from the engine? Would appreciate some feedback
Thanks! |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Thu Oct 30, 2014 10:17 am Post subject: |
Removing a stripped or broken stud is a pain. Sometimes it is easy & sometimes....not. A dremel may work for you. I would try to warm it up a bit & work it out with a pair of vice grips. _________________ I think he meant "rare", as in "not well-done" |
supersuk Samba Member
Joined: December 20, 2010 Posts: 958 Location: Honolulu, Hawaii
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
asesapie Samba Member
Joined: March 07, 2005 Posts: 756 Location: Spokane, WA
Posted: Thu Oct 30, 2014 2:20 pm Post subject: |
I agree with welding a nut to the top of it. That is a great method of removing studs. Maybe a bit of PB blaster to soak on it before welding |
JesusGreen Samba Member
Joined: October 20, 2014 Posts: 29 Location: Surprise AZ
Posted: Fri Oct 31, 2014 1:13 am Post subject: |
You could just run a die over the stud and recreate new threads and use two nuts, no welding or removing of the stud |
ddare Samba Member
Posted: Sat Nov 01, 2014 5:54 am Post subject: |
Thanks for the pointers, guys. The stud came out pretty easily once I tightened the two nuts together and backed out the inner nut. Fortunately none of the threads in the head were damaged. I had an extra stud lying around so I was able to swap it out without making a run to the parts store. But now I know for next time what my options are. |
