Henrik_K Samba Member
Joined: November 17, 2013 Posts: 181 Location: Denmark
Posted: Thu Oct 30, 2014 12:11 pm Post subject: Ignitor ignition with 009 |
Hi,
I've bought a brand new 009 Distributor with points - but without Vacuum advancer...
Will any Ignitor from Pertronix fit and work with this?
Also can you recommend a webshop in Us that sells this?
Thanks,
Henrik |
Tcash Samba Member
Posted: Thu Oct 30, 2014 2:05 pm Post subject: Re: Ignitor ignition with 009 |
Henrik_K wrote: |
Hi,
No
http://www.pertronix.com/
Thanks,
Henrik |
Good Luck |
sambabus Samba Member
Joined: December 02, 2009 Posts: 324 Location: N. Cal
Posted: Thu Oct 30, 2014 3:17 pm Post subject: |
Just order the one that says it works with the 009.
CB should have one:
http://www.cbperformance.com/ProductDetails.asp?ProductCode=2041
009 might not be the best choice for a small motor but it works. Check the range of timing carefully. _________________ 1971 Westy, 2017cc 78.4 x 90.5 Tims Stage 1 plus 42x37, CB 44IDF's, 135 mains, 175 airs, F111, 50 idles, Engle 110, 30mm, 009, single QP, DD CHT 300*f, VDO oil always 180* Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=541370
1970 convertible bug, 1835cc, single 40IDF, disks.
Symptoms Solved and Fixed http://www.thesamba.com/vw/forum/viewtopic.php?t=551358 |
