tjet Samba Member
Posted: Thu Oct 30, 2014 6:03 pm Post subject: Stripped headlight screw :( |
One of the headlight screws is stripped (see pic.)
Is there a way to get it out without breaking the plastic piece in the back?
Here is the cleaning procedure I plan to do
http://www.youtube.com/watch?v=SOWX2yxaKSk
Altoona Samba Member
Posted: Thu Oct 30, 2014 6:41 pm Post subject: |
You sure that isn't one of the non-adjustable ones? |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10250 Location: N. Idaho
Posted: Thu Oct 30, 2014 6:59 pm Post subject: |
That's just a positioning mount - not a headlight aduster. Those adjusters and the entire mounting system can be a pain. Easily replaced with $20 worth of big box hardware and there's a great thread on it. You'll have full adjustability for ever, and clean lights. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Thu Oct 30, 2014 7:01 pm Post subject: |
PS - don't remove the headlights from the metal frame. Just take the entire frame out and clean them two at a time and don't mess with old ajusters and fragile plastic mounts. 4 screws and you'll have two headlights in the sink. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
tjet Samba Member
Posted: Thu Oct 30, 2014 7:10 pm Post subject: |
Ok thanks. Will leave em in the frames |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
bluebus86 Banned
Posted: Fri Oct 31, 2014 10:06 am Post subject: |
to help keep the plastic from getting UV damaged, I slip some heat shrink tube over the ends and shrink it over the ends that will be exposed to sunlight thru the grill. I general leave them be, easy to have them shatter if you try to remove them. replacements are pricey. If I need to turn the adjusters, I give the threads a squirt of silicone lube to ease the screwing process. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
insyncro Banned
Posted: Fri Oct 31, 2014 10:12 am Post subject: |
Not striped and non adjustable as mentioned.
All of the posts can be removed from the metal holder if they are not brittle.
Look at the tabs, push them in and spin the plastic base, done deal, twist to reinsert. |
tjet Samba Member
Posted: Sat Nov 01, 2014 5:27 pm Post subject: |
I followed the go westy procedure using mild dishwashing liquid (instead of degreaser), followed by watered down Windex & a thorough rinse. I left them in the buckets as doug suggested. I tried to move the plastic adjusters, but they weren't going to budge. I didnt use a brush, just swished the hot water around. I did a final rinse using warm distilled water because the tap water at my house has lots of minerals. I shook most of the water out & placed them in the oven at 190* (once it got to 190, I turned it off & let them stay in there for a couple of hours). Anyway - they came out looking new. They were cloudy / hazy before I did this.
I also ordered a pair of clear lexan covers - see link below.
http://www.summitracing.com/parts/wam-72-90277
& thx for the tips. Will lube up the screw threads before I put the headlights back in...
Also found a good deal for German bulbs...
H4 Low beams
http://www.ebay.com/itm/2PCS-Genuine-Philips-Bulb-...mp;vxp=mtr
H3 Hi Beams
http://www.ebay.com/itm/301108565605?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
There's also a very small bulb on the side of the low beams (on outboard side of the reflector). I have a p/n, but I'm not finding it on line. It's T4W37R |
1vw4x4 Banned
Posted: Sun Nov 02, 2014 6:52 am Post subject: |
Don't waste your time with those plastic adjuster. Put all the pieces
back in place, broken out not, and use an epoxy glue, to glue them in
place. By now they are all brittle and a heavy wind will break them.
I go over them all, with glue, even if they are in good shape.
The South African grill is an absolute piece of junk. Don't waste your
money on this ether. If you want round head light buy an early model
grill and headlights. A nice upgrade to this grill is the H4 Z beams. |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Sun Nov 02, 2014 8:28 pm Post subject: |
Lots of people really like the South African Grill, but it is not nearly as sturdy as the OEM grill found on the 1980-1985 Vanagon. I have installed several of the SA Grill's for friends and they have all really loved the results. So far they have held up pretty well, but it is important to use a delicate touch when installing or removing them since the plastic is considerably thinner than the stock 80-85 grill.
The Cibie Z Beam H4's that 1vw4x4 mentions are definitely a great headlight setup, but they were discontinued years ago. I occasionally keep an eye out for them on eBay, but they have been selling for $200.00-$300.00 a set for NOS condition lately.
The best deal on Cibie 7" round H4 e-Code lenses I have found is from amazon.com http://smile.amazon.com/Cibie-082440-Light-Unit/dp...=cibie+h4. I am running these on my '85 Westy with Osram Hyper 85/80W H4 bulbs and am more than pleased with the results.
These lenses would be a great choice if you do decide to install the SA Grill down the road. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Sun Nov 02, 2014 8:57 pm Post subject: |
The SA grill is not a piece of junk. I have the SA grill on 3 of my vans and I haven't been able to break them or damage them in any way- the oldest being a decade old. |
tjet Samba Member
Posted: Sun Nov 02, 2014 9:37 pm Post subject: |
thatvwbusguy wrote: |
Thanks (and to 1vw4x4) on the better light assembiles if I install the round lights w/early grille |
Posted: Sun Nov 02, 2014 10:43 pm Post subject: |
I agree with syncrodoka completely, the South African Grill is far from a piece of junk! I would install on one my van without a moment's hesitation.
There is no other readily available solution that will produce better lighting for the front of the Vanagon. With quality 7" outer lenses, good bulbs and proper headlight aiming, stock wattage will produce more than acceptable performance for most people's needs. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
tjet Samba Member
Posted: Sun Nov 02, 2014 11:54 pm Post subject: |
1vw4x4 wrote: |
Mine have H4 on the lens. Is that good, or is that how all the retangular ones are? |
Posted: Mon Nov 03, 2014 1:16 am Post subject: |
The rectangular H4's from the European market are about a million times better than the DOT lenses with 9004 bulbs we got in the US, which is why the H4's typically command such a high price in the resale market.
With that said, I still prefer the look and performance of a high quality 7" round headlamp. The Cibie e-Code lens with Osram Hyper 85/80W H4 is the best combination that I have found for the Vanagon in any form of stock headlight configuration.
Most Hella e-Code lights tend to have an unusually wide differential between the low beam and high beam settings. For instance, if you properly aim the headlights on low beam, your beam focus will be up in the trees on high beam. In my experience, the Cibie's tend to have a more constrained focus that creates a very usable beam on both settings.
I am not sure to what degree this is the case for the OEM Vanagon H4 rectangular lights, since I have never personally aimed a set via the common method shown here: http://www.danielsternlighting.com/tech/aim/aim.html _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
Merian Samba Member
Posted: Mon Nov 03, 2014 12:17 pm Post subject: |
The SA grill is flimsy and feels like a piece of junk. Mine has lasted several years and who knows how much longer it will last. I agree it is not really junk.
The SA kit is way overpriced and ripe for some 3D printing competition. OTOH, you will not want to wait, so buy it. Or if you have no money but like to waste time on projects, find an '85 or earlier round grill and cut new holes in it as per some threads you can locate here.
I think the real problem with the square stock headlights is the reflector design, and good bulbs (with relays) will merely mitigate the issue somewhat. Round is the way to go.
Toss the square stock headlights in the dumpster as they cannot be recycled -- or give them to an enemy you wish to chastise. |
Posted: Mon Nov 03, 2014 5:16 pm Post subject: |
The choice of the 9004 bulb, with its transverse filaments, combined with what most people deem to be a less than stellar reflector design for the USDOT lenses both contribute heavily to unsatisfactory lighting results.
Since the OP has the much sought after Euro H4 version of the rectangular lenses, he is way better off than folks with the USDOT version. A large portion of the cost of the SA Grill kit could likely come from selling the Euro lenses to someone strongly attached to the aesthetic of the rectangular lenses.
The idea of a 3D printed grill does seem very appealing, but the cost of a printer large enough to print something the size of the grill would be incredibly expensive. The up front expense of equipment and the routine maintenance to keep it operating properly must be factored into the cost of the parts it produces, even on a contract manufacturing basis.
Long term durability of 3D printed parts constantly exposed to the elements is something worth considering as well. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
tjet Samba Member
Posted: Mon Nov 03, 2014 10:27 pm Post subject: |
Thanks for all the replys. Anybody have a good part # for the small bulbs that go into the side of these H4 low beams? I believe it's called a "city" light. |
