1976 westi
Schultzy'sVW
Schultzy'sVW is offline
PostPosted: Thu Oct 30, 2014 6:37 pm    Post subject: 1976 westi Reply with quote
Just bought a 76' westi that was sitting for over 8 years. Looking for someone in the Delaware area to go over the motor. I'm going to pull the engine so that I can drain the tank after sitting for over 8 yrs with about half a tank of gas.
I am open for any suggestions as to help.
Waves2day
Waves2day is offline
PostPosted: Thu Oct 30, 2014 6:44 pm    Post subject: Reply with quote
Congrats! Welcome to the 76 club. Pictures if you can...
Sam
1976 Westfalia Camper Pop-top
1972 Westfalia Hardtop (sold)
Tcash
Tcash is offline
PostPosted: Thu Oct 30, 2014 6:58 pm    Post subject: Reply with quote
Hi
You can get the gas tank out without pulling the engine.
Look under (General Service/Repair) for a shop near you.
VW Business Listing
Tcash wrote:
Here is a little information. Good Luck
Pronunciation (Samba) English
Cleaning+Rodents+Hantavirus
Up in smoke... Bus fires... don't let it happen to you!
Volkswagen Type 2 Bus M-Plate Decoder
Bus VIN / Chassis Numbers
Type 2/Bus Owner's Manuals
Bus repair manuals
Bus parts manuals
Early Baywindow Bus Parts Book
Late Baywindow Bus Parts Fiche
Type 2 Wiring Diagrams
Model and Year Variations
Type 4: Secrets Revealed
Distributor Parts & Specifications
PARTS INTERCHANGE MANUAL
Youtube Videos
There is a ton of information located at the top of the Forum section.
busdaddy
busdaddy is offline
PostPosted: Thu Oct 30, 2014 7:58 pm    Post subject: Reply with quote
Just to save Hazetguy the trouble:
Westi:
Westfalia (aka Westy) :
Smile Wink
Слава Україні!
Schultzy'sVW
PostPosted: Fri Oct 31, 2014 5:27 am    Post subject: Reply with quote
Thank you for the heads up on the sp mistake that will save me a lot of comments
eche_bus
eche_bus is offline
PostPosted: Fri Oct 31, 2014 3:14 pm    Post subject: Reply with quote
Hehe ... just don't call it a "van". Wink
Welcome! Very Happy
thebusandus
thebusandus is offline
PostPosted: Fri Oct 31, 2014 3:21 pm    Post subject: Reply with quote
Sounds like a sweet van Wink
2.2 Suby powered - 75 Westy - Rita
Panamerican Highway - 2014-2017
jhicken
jhicken is offline
PostPosted: Fri Oct 31, 2014 3:31 pm    Post subject: Reply with quote
Unless you are from New Jersey! Wink
Der Kleiner Kampfwagens
jhicken
jhicken is offline
PostPosted: Fri Oct 31, 2014 3:34 pm    Post subject: Reply with quote
Tcash wrote:
Hi
You can, but it's a PITA. If you pull the motor to remove the tank, you can spend a little time cleaning everything up, fix any leaks, replace engine seals and generally get to know your bus a little better.
-jeffrey
Collie
Collie is offline
PostPosted: Fri Oct 31, 2014 3:56 pm    Post subject: Re: 1976 westi Reply with quote
And nobody caught that typo either? Shocked
I thought it may have been a "stretch" bus.....
Bala
Bala is offline
PostPosted: Mon Nov 03, 2014 9:45 am    Post subject: Reply with quote
Welcome! Yes, pictures! Smile
1976 Westy
1966 Beetle
