Thing transmission - which are compatible?
Doward1962
Doward1962 is offline
PostPosted: Mon Nov 03, 2014 9:17 pm    Post subject: Thing transmission - which are compatible? Reply with quote
I have a 74 Thing and I'm looking to replace the transmission. What other air cooled transmissions are compatible with the Thing - any IRS tranny?
Pierre G
Pierre G is offline
PostPosted: Tue Nov 04, 2014 4:04 am    Post subject: Re: Thing transmission - which are compatible? Reply with quote
Yes, any Type1 IRS trans can be compatible, but CV joints are Thing specific.
You will have to do a mix of parts.
1976 181/Thing, 1967 fastback, 1973 squareback, 1964 microbus, 1967 Double Cab, 1969 westfalia (currently under resto), 1972 LM1C dune buggy, 1974 jean's bug, 1974 1303 (super beetle, currently under reassembly after new paint).
waxhead
waxhead is offline
PostPosted: Tue Nov 04, 2014 6:05 am    Post subject: Reply with quote
You may also have to use a different transmission mount. I have a '75 bug transmission on my Thing. I had to find the mount with the 3 studs:
You could also switch out the nose cone, but I thought this was easier.
Mike B.
Mal evolent
Mal evolent is offline
PostPosted: Sat Nov 08, 2014 8:25 am    Post subject: Reply with quote
remove the Thing CV flanges before you have a transmission rebuilt. they tend to migrate if not watched carefully.
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
mcmscott
mcmscott is offline
PostPosted: Sat Nov 08, 2014 11:10 am    Post subject: Reply with quote
Only at a shitty trans shop. If a shop steals your flanges, they are a dis honest shop and you should stay far away.
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
gears
gears is offline
PostPosted: Sun Nov 09, 2014 11:19 am    Post subject: Reply with quote
You're generally better off rebuilding your original Thing transaxle, as it has a better R&P than compatible (non-Thing) replacements. At the very least, don't turn your original in as a core. Keep it for future rebuilding.
aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com
Aircooled Werk
Aircooled Werk is offline
PostPosted: Sun Nov 16, 2014 9:27 am    Post subject: Reply with quote
As a builder, I would advise you to rebuild yours and only a dishonest shop would take your CV flange.
JonnySox
JonnySox is offline
PostPosted: Tue Mar 10, 2015 9:54 pm    Post subject: 2 Thing Trannys Reply with quote
i have two working Thing trannys that need homes. I am in Salt Lake City. What are they worth?
strelnik
strelnik is offline
PostPosted: Wed Mar 11, 2015 6:24 am    Post subject: Re: 2 Thing Trannys Reply with quote
What year were they made? which mounts?
L'audace! L'audace! Toujours l'audace!
liken127
liken127 is offline
PostPosted: Wed Mar 11, 2015 6:41 pm    Post subject: Reply with quote
I had mine rebuilt, and they powder coated the case, spent about $950.00
Did a little gear work also.
