vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Wed Nov 05, 2014 9:05 am Post subject: |
It's bad ass. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Pat D Samba Member
Posted: Wed Nov 05, 2014 9:22 am Post subject: |
We will post the Gen 4 ecu feature list later today on the CB site. _________________ Pat, Im too fast slow me downs! |
vince1 Samba Member
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Wed Nov 05, 2014 2:14 pm Post subject: |
When you say 'bad-ass'... how does it compare to Haltech, Microtech, MoTeC, Megasquirt etc? |
Pat D Samba Member
Posted: Wed Nov 05, 2014 2:55 pm Post subject: |
ECU features
32bit processor, Marine grade locking connectors, 4mb of internal storage
8 High or Low impendence Injector drivers.
4 On board Direct Fire Ignition Drivers. Each driver can fire up to 2 coils.
8 Smart Coil drivers
VR Crank and Cam Input (36-1 Trigger Wheel supported for crankshaft position)
Hall Effect Crank and Cam Input
Coil Negative input (also accepts this input as a ignition timing control through points or points replacement modules)
8 Analog 0-5 volt inputs
8 Digital Inputs
On Board 2.5 Bar MAP sensor or external 1,2,3 or 5 Bar MAP input
On Board Barometer sensor (Adjusts tune automatically for altitude)
4 On Board Wideband O2 sensors
4 On Board K-Type EGT controllers
H-Bridge IAC Controller
Gas, Methanol or E-85 Compatible (AFR displayed in gasoline scale)
Boost Controller
Water/Meth Controller
6 Outputs (1-amp max each)
Rev-Limiter and 2-Step Rev Limiter
Software Features
20x20 Fuel, Ignition, Air Fuel Ratio, Learning, High/Low learn limits, Water/Meth Table Sizes.
Speed Density or Alpha-N configurable load boundaries
Pulse Width or VE based Fuel Table tuning strategies
Individual Ignition coil trim
Individual injector trim, including Idle – Midrange and wide open throttle
Assisted tuning strategy via closed loop and learning, user selectable
Adjustable Spark Dwell based on load and Temperature
Temperature based timing compensation
Internal data logger allows you to export data after run or tuning session
Turbo Over boost and Anti-lag
Sensor low and high limits settings, with sensor fail defaults
Temperature based enrichment settings
Air Intake Temp Compensation
Selectable Voltage Injector trim
Staged Injection via TPS and/or MAP _________________ Pat, Im too fast slow me downs! |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Nov 05, 2014 3:12 pm Post subject: |
And the magic question.... $$? _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Pat D Samba Member
Posted: Wed Nov 05, 2014 3:24 pm Post subject: |
jfats808 wrote: |
And the magic question.... $$? |
We are not exactly sure as of yet. We are trying to keep the retail price at $795.00 for the ECU and $2,395.00 for the complete EFI system. _________________ Pat, Im too fast slow me downs! |
Posted: Wed Nov 05, 2014 3:40 pm Post subject: |
Pat D wrote: |
jfats808 wrote: |
We are not exactly sure as of yet. We are trying to keep the retail price at $795.00 for the ECU and $2,395.00 for the complete EFI system. |
Thanks Pat. I have a quicktune kit in boxes and dubshops hideaway crank gear set up. I was exploring options between running ms2 3.57 and the additional accessories vs adding on the 2094 kit and quicktune. And now this new system in the works eliminates additional connections and wires albeit almost 200 more additional. Whats the possibilities that the kit can be purchased at a little reduced cost less the crankfire accessories? Thanks, I want to explore my options. _________________ 2276 IDA's 86C 11-1 DD !
Pat D Samba Member
Posted: Wed Nov 05, 2014 4:27 pm Post subject: |
The complete Gen-4 efi kit does not include the crank trigger hardware. All ignition components, crank trigger hardware, cam synch are sold separately. _________________ Pat, Im too fast slow me downs! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Nov 05, 2014 4:43 pm Post subject: |
Pat D wrote: |
The complete Gen-4 efi kit does not include the crank trigger hardware. All ignition components, crank trigger hardware, cam synch are sold separately. |
So plus another $200-400....
What type connection for tune, USB or RS-232 or bluetooth? Does software come with it does it support ANDROID....
Posted: Wed Nov 05, 2014 4:49 pm Post subject: |
Pat D wrote: |
So in actuality for my particular set up question, all I would need is a quad tower coil and the new efi system? Since the drivers are already on board? I like that the new proposed system has more inputs to add on additional systems like pump intercooling, oil fan coolers, etc im still learning efi particulars so pls correct me where im wrong. Thanks. _________________ 2276 IDA's 86C 11-1 DD !
Chip Samba Member
Posted: Wed Nov 05, 2014 7:30 pm Post subject: |
Pat D wrote: |
ECU features
8 Digital Inputs
Boost Controller
Software Features
Staged Injection via TPS and/or MAP |
Sounds VERY impressive!
Price sounds good too! |
Pat D Samba Member
Posted: Thu Nov 06, 2014 8:58 am Post subject: |
We tried to pack as many options into this ecu as we could, keeping it within a price point our industry can handle. Mark and I have been Beta testing the ecu for over a year and are very happy with the results. We have added many options that our Magna F/S ecu did not have. _________________ Pat, Im too fast slow me downs! |
Posted: Thu Nov 06, 2014 9:13 am Post subject: |
Pat D wrote: |
We tried to pack as many options into this ecu as we could, keeping it within a price point our industry can handle. Mark and I have been Beta testing the ecu for over a year and are very happy with the results. We have added many options that our Magna F/S ecu did not have. |
It's definitely packed with features! If you stay within your targeted price, it's like buying a data-logger for 4-channel EGT and O2, and getting the EFI/ignition control for free.
Regarding the 1-amp outputs, are these just switched outputs, or PWM? If PWM, how many channels?
*IF* this ECU had a CANbus datastream that could be interpreted by a PCS device, I'd sell my Electromotive Tec-GT today and run your new ECU. Very impressive work! _________________
66brm wrote: |
Bodacious wrote: |
Pat D Samba Member
Posted: Thu Nov 06, 2014 10:17 am Post subject: |
Stripped66 wrote: |
Pat D wrote: |
*IF* this ECU had a CANbus datastream that could be interpreted by a PCS device, I'd sell my Electromotive Tec-GT today and run your new ECU. Very impressive work! |
The Gen-4 does have a canbus, we have not yet interfaced it with anything to date. As far as the GPO's, the only GPO so far that is PWM is the water/meth output. What is it that you want to PWM? We have intentions later on for nitrous control and will PWM the selenoid. _________________ Pat, Im too fast slow me downs! |
Posted: Thu Nov 06, 2014 11:51 am Post subject: |
Pat D wrote: |
The Gen-4 does have a canbus, we have not yet interfaced it with anything to date. As far as the GPO's, the only GPO so far that is PWM is the water/meth output. What is it that you want to PWM? We have intentions later on for nitrous control and will PWM the selenoid. |
Shouldn't the boost controller also be PWM, or is this not counted in your 6 GPOs (because it's not a GPO but its own output)?
I use PWM for my wastegate solenoid and my VGT turbo. And, although it would also be nice to have a configurable PWM table that could incorporate variables other than MAP and RPM, I realize this is not a remote concern for your intended market.
Right now, the only thing holding me to Electromotive is the 2 PWM outputs and it will talk to PCS via CAN. Regardless, I don't expect all of my needs to be met by a sub-$1000 ECU...you have packed a phenomenal number of features into that ECU for the cost, which is very commendable. _________________
66brm wrote: |
Bodacious wrote: |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Thu Nov 06, 2014 12:23 pm Post subject: |
sounds great... hope to be able to get one next year as I make progress on my build _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Thu Nov 06, 2014 12:32 pm Post subject: |
Just wondering.....because not far off I will be diving into an aftermarket injection system for a friends 914 engine.
When you say "marine Grade locking connectors"....whose connectors?
By that I mean whose connector design is inside of the plug body? If its EV-1 style dual cantilever or a manufactured under license equivalent....very cool!
I'm hoping its NOT the pre-EV-1 GM/Delphi Weatherpack system with the round molex pin or the single cantilever connector.
While Weatherpack was is the BEST SEALING connector body on the market.....even GM quit using (for the most part...finally) the early pre-EV-1 connectors in their systems because of the horrible long term reliability.
Just asking because the connector and harness systems are usually the weak points of most aftermarket programmables. Ray |
Pat D Samba Member
Posted: Thu Nov 06, 2014 12:38 pm Post subject: |
Stripped66 wrote: |
Pat D wrote: |
Right now, the only thing holding me to Electromotive is the 2 PWM outputs and it will talk to PCS via CAN. Regardless, I don't expect all of my needs to be met by a sub-$1000 ECU...you have packed a phenomenal number of features into that ECU for the cost, which is very commendable. |
Sorry, The boost control, nitrous control and water/meth control are all dedicated PWM outputs. _________________ Pat, Im too fast slow me downs! |
