deanomont Samba Member
Joined: September 06, 2009 Posts: 214 Location: Kansas City MO
Posted: Wed Nov 05, 2014 1:09 pm Post subject: new paint removal |
Hello,
This is coming from someone that knows very little about paint and body.
The PO quite possibly pulled off the worst paint job I have ever seen! This stuff was peeling off before I bought it, so I knew what I was getting in to.
Its hard to tell from the pic, but the new paint is quite a bit darker than the og Miami blue underneath.
The flakes coming off appear to be clear causing one to believe that it is just clear coat, however I am certain that I'm looking at the original paint underneath, which doesn't look too bad. According to PO the paint looked pretty good before he painted it, just oxidized. Judging by the og paint I see, I think I might be able to cut and buff it back in to shape.
I want to attempt to carefully remove all the new paint down to the original and then see what I have to work with. If it looks like crap then I will decide what to do from there.
Now my question:
How do I safely remove the paint without damaging the og paint underneath. I have seen some folks on here using graffiti remover, but my local paint shop says no way. Would sanding it be a better method? My concerns about sanding is that it will be incredibly difficult to not damage any of the paint I want to keep.
Of course, I think if I left it out in the sun for a few more months all the paint will fall off on its own..lol
Thanks in advance for any input.
Let me know if you need some more pics. I will be happy to go out and snap a few. This is just one I already had in the gallery. |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Wed Nov 05, 2014 2:16 pm Post subject: |
Good grief. That looks like a tricky mess to remove. I would be temped to try some lacquer thinner on a rag and see if it softens and removes only the clear coat. It shouldn't affect the original paint unless it is soaked for a very long period of time. Unless that isn't the original paint underneath. It's risky. _________________ 1958 Karmann Ghia owner |
Posted: Wed Nov 05, 2014 2:24 pm Post subject: |
Any thoughts on the graffiti remover? |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Wed Nov 05, 2014 2:30 pm Post subject: |
sanding. |
Posted: Wed Nov 05, 2014 2:32 pm Post subject: |
Maybe even a low powered pressure washer. _________________ 1958 Karmann Ghia owner |
Posted: Wed Nov 05, 2014 2:44 pm Post subject: |
What grit sand paper should I use if I sand it? could I use a DA? That sounds riskier than the graffiti remover..
Remember, my objective is to try and save the og paint..
No graffiti remover? The dude in one of the stickys removed all the paint on his bus and was even able to save the og logos that were underneath, but like I said before, a pro body guy told me not to use unless I want to take it down to bare metal (confusion). Maybe I'll try a little on an inconspicuous area..
Just trying to get a clear idea.. that is an awful lot of sanding to do!
Thanks |
c21darrel Samba Member
Posted: Wed Nov 05, 2014 2:54 pm Post subject: |
Here is another shot of the roof.
It seems that it peels the most when its hot out. Maybe I'll use a heat gun, but then I run the risk of burning something.
Posted: Wed Nov 05, 2014 2:56 pm Post subject: |
c21darrel wrote: |
I have used grafitti remover. I was taking off a rattle can paint job and it worked with plenty of elbow grease. did not damage the og VW paint. |
Can you tell me in a little more detail your method?
How many cans did you use?
How long did it take?
Thanks |
