bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Wed Nov 05, 2014 3:03 pm Post subject: 16" radials |
I have seen a couple of cars recently sporting Michelin X 16 radials which look nice and retro but must handle quite nicely. These only seem to come in 185 width so I was wondering if anyone has them on stock 16" beetle rims and how they handle and what compromises do you get - do they rub the arches, reduce turning circle etc:
Cheers,
Dave |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Wed Nov 05, 2014 3:29 pm Post subject: |
in your picture they are in fact 175 wide. 175/80/16 diameter is about a half inch more than a stock 5.00/5.25 16 tire.
i bet they fit the rims and i would not be surprised if they did not rub just a tad on the inside. I had some winter bias plies on my old bug, 5,60 15s, and they did rub occasionally. never a problem, put 10s of thousands of miles on it.
tire does look nice _________________ regards
Uli
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 986 Location: Bath, England
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Thu Nov 06, 2014 4:48 am Post subject: |
take a guess at what new (Michelin) 16 inch bias ply tires cost..... _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Thu Nov 06, 2014 12:35 pm Post subject: |
I sold Michelin tyres many years ago, and we was told that Michelin could produce any tire they had produced before, on special order.
But it comes to a price, and maybe a year delivery time for the most special tires. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Standardfahrer Samba Member
Joined: December 30, 2009 Posts: 42 Location: Germany
Posted: Mon Nov 10, 2014 6:10 am Post subject: |
I have them in 5.00/5.25 with white walls on my split beetle.
I don't have a direct comparison on this car, but they seem to be "harder" than the bias plye tyrers on my other split.
The tire wall seems to be smaller too.
Marcus |
Posted: Mon Nov 10, 2014 10:25 am Post subject: |
the sidewall on a bias ply is basically 100% of the width of the tire. the Michelin X is a 80% tire. the sidewall is 80% if the tire width.
makes sense that the sidewall would be shorter, and in general bias plies are a good bit "softer". they run with a lot less air in them _________________ regards
Uli
beetleseb Samba Member
Joined: November 09, 2006 Posts: 430 Location: Cheltenham UK
Posted: Tue Nov 11, 2014 2:16 am Post subject: |
175/80/16 are quite easy to get hold of in the UK. They are a stock taxi tyre size and start from £50 a rim.
I've seen them on barndoor busses and on one bug with barndoor rims. Look great but 3" may be a bit tight.
I could do you a deal on the crossplys you have tucked away tho
Seb _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
Posted: Tue Nov 11, 2014 2:34 am Post subject: |
Oh and tyre traders have Michelin at £85 in that size
allsidius Samba Member
Joined: February 02, 2010 Posts: 1475 Location: Norway
Posted: Tue Nov 11, 2014 6:51 am Post subject: |
175/80 are too big in circumference. You would want 145s for the 16 inchers.
The sidewall of the old 5.00 16s were 5x25,4 = 127 mm (width and sidewall are equal on crossplies). To get the corresponding radial, you need to divide by 0.83 which is the default ration of a radial tyre, you get 153 mm. So, 155 R 16 would be the closest size. Now we all know that VW put 155 R 15 on late 60s beetles, which would be a little too skimpy, at least compared to the original 5.00x16 wheel radius. With the introduction of the Zwitter, the tyre size changed to 5.60x15, which is the closest to the theoretical 5.5 wide tyre you would need to compensate for the 1 inch smaller rim. So, the 5.60x15 is a tad bigger than the 5.00x16 of the Splits.
Back to the radials, my 1973 1303 instruction manual still quotes 155 SR 15 for the beetle, although 165s would correspond better to the original wheel diameter. So, to decrease the side wall when going up to 16 inch rims, you need to subtract app. half an inch from the width, ending up with 145 SR 16 (you need to give or take a little when calculating tyre sizes). I don't know if you can get it, but 175s with default ratio (0.83) are certainly way too big by almost 2 inches on the diameter. _________________ 1973 1303S w sunroof Click to view image
1978 1303 convertible (sold)Click to view image
1966 1300 RIPClick to view image
Posted: Wed Nov 12, 2014 12:13 pm Post subject: |
Not 100% on the maths but if you look at the rolling diameters of the 5.00/5.25 tyres on vintage tyres website and the 175's there is as little as 5mm in it. It would only be the width I'd worry about on the 3" rim
175 are 690mm
Waymaster 5.00/5.25 are 685mm others are a little smaller but only 680mm or so _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
