Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Dec 16, 2014 3:03 am Post subject: |
You can see from the images below that the model stampings are a lot more crude in appearance for this type of badge. You might have to enlarge some of these to get a better image.
Here is a better image of a slightly earlier typical badge from December 1953.
_________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
TheLadyBug Samba Member
Joined: August 17, 2014 Posts: 639 Location: Saskatoon, Saskatchewan, Canada
Posted: Sat Dec 27, 2014 9:20 pm Post subject: |
Does anyone have any info on what lower pulleys were used in 54? I've heard there were 3 used and I'm trying to decipher which was appropriate for February. _________________ Charmaine
1954 Beetle - because I can
2016 Golf highline - hubby’s daily
2016 Golf R - my daily |
janerick3 Samba Member
Posted: Mon Dec 29, 2014 6:14 pm Post subject: |
Thin-lipped pulley without the radial lines, used 1954-mid 1956. Thin-lipped pulleys w/radial lines are 25hp. _________________ Thanks,
Jan K. |
Posted: Mon Dec 29, 2014 8:16 pm Post subject: |
janerick3 wrote: |
Thin-lipped pulley without the radial lines, used 1954-mid 1956. Thin-lipped pulleys w/radial lines are 25hp. |
Thanks! Would you be extra awesome and show me a photo? _________________ Charmaine
laneven28 Samba Member
Joined: January 09, 2007 Posts: 312 Location: Cedar Hills, Utah
Posted: Mon Dec 29, 2014 9:32 pm Post subject: |
I don't have a picture of a 25hp pulley, but here are pictures of an early thin lip 36hp pulley (the unpainted one), and a later full lip 36hp pulley (the black one on the engine).
_________________ 1950 Pearl Grey Hoffman Standard Split Window
1954 Iceland Green Euro 3-Fold Oval
1955 Strato Silver Transitional 3-Fold Oval
1956 Iris Blue Convertible
1958 Pearl White Lowlight KG Convertible
1961 Turkis Ragtop |
Posted: Mon Dec 29, 2014 9:47 pm Post subject: |
Thank you! So I should be looking for the first one then.
Am I correct to assume there were only 2 thin lipped pulleys, and only 1 used on 36hp, as the later cars used a rolled lip? _________________ Charmaine
Posted: Mon Dec 29, 2014 10:26 pm Post subject: |
TheLadyBug wrote: |
Am I correct to assume there were only 2 thin lipped pulleys, and only 1 used on 36hp, as the later cars used a rolled lip? |
Yes, you're correct. The 25hp thin lip pulley has the radial lines extending out from the center so they're easy to spot. Here's a picture I found in the gallery of a 25hp motor - you can see the detail of the pulley quite well.
Abscate Samba Member
Posted: Tue Dec 30, 2014 2:56 am Post subject: |
I'll check my parts stash, Char.... _________________ .ssS! |
