langan Samba Member
Joined: December 31, 2010 Posts: 423 Location: Eagle ID.
Posted: Sun Nov 09, 2014 8:57 pm Post subject: Can you built trans at home? |
If a guy wanted to build a Freeway flyer trans at home where could he find parts an info? |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Sun Nov 09, 2014 9:24 pm Post subject: |
There's a transmission forum over at www.ShopTalkForums.Com if you're really serious. But keep in mind, the required specialty tools alone will cost more than one trans. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sun Nov 09, 2014 9:28 pm Post subject: |
The Bentley repair manuals have a complete chapter with pictures and a list of all the special tools you will need on rebuilding a VW transaxle. Long Enterprises sells a DVD on rebuilding them.
If your only going to rebuild one transaxle it will cost you more to buy all the special tools and jigs then to pay a shop to do it for you. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Sun Nov 09, 2014 10:39 pm Post subject: |
Everything above, plus u need access to a hydraulic press. You'll need to build about 5- 6 gear boxes to make the purchase of specialty tools worth it. This also includes the "learning curve" or more popularly known as the oops factor.
I bought my trainer discs from Long and I buy parts from them, geno boyd and Rich robertson. Others to purchase are erco , rancho, and weddle. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
nsracing Samba Member
Posted: Mon Nov 10, 2014 6:04 am Post subject: |
Sure...if you have all the tools, press, jigs and other machines to refurbish the middle housing.
If for no other reason other than you want to learn how to do it, practice on a dummy transmission. Just take it apart and clean and see if it is what you want to do. It is quite a bit of money to get going in the trans rebuilding.
But I would not recommend setting up the whole bit and just do one. Not worth it.
I already had my machines and toolings so it was a natural progression for me to do transmissions.
Hope this helps. |
langan Samba Member
Posted: Mon Nov 10, 2014 7:08 am Post subject: |
We're do you buy the tools and parts? |
Posted: Mon Nov 10, 2014 7:34 am Post subject: |
well...you have to collect them all!
LIke I said...it is not worth if only doing 1 or 2 units. YOu are better off paying for a trans. |
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
bluebus86 Banned
Posted: Mon Nov 10, 2014 10:54 am Post subject: |
If you learn how to use bluing and read the gears you can get buy without many of the fixtures. It is a slower process this way and requires sometimes many assembly /reassembly cycles, but it can be done. If your only doing one tranny and have the time that is a good way to go. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
busdaddy Samba Member
Posted: Mon Nov 10, 2014 11:24 am Post subject: |
Aside from the tools you'll also need a large selection of shim washers to mix and match to find the correct combination for your box, another reason to let a pro with the existing parts stash do it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
raygreenwood Samba Member
Posted: Mon Nov 10, 2014 11:38 am Post subject: |
Yes....and no.....
I am not a transmission expert but I have worked on and rebuilt more than a handful.
I think there needs to be a bit more Q&A before just saying its too expensive to do only one transmission.
Everyone immediately assumed it was a type 1 based transaxle (probably is.... but still).
What Kind is it?
Yes....building a freeway flier (meaning changing gear ratios and/or R&P) will require quite a bit of measuring....
......but for the benefit of those reading who are not changing ratios but who may be just doing a general reburb.
Its fully possible to to that without a lot more than the intermediate plate jig and a good set of micrometers, good torque wrenches in inch lbs, dial indicators and extensions/mounts/clamps etc.
Yes...you need a press. A serviceable one can be had from HF for between $125 and $200
This means changing bearings, setting pre-load, lash and measuring synchros.
The real question is what other than the obvious needs to be done on this guys freeway flier.
Usually if you are doing more than just extending the life of the transaxle.....meaning doing a FULL rebuild.....which will require a ton of tools......then yeah....send it out.
I note this because the transmissions I spend most of my time working on are type 4....004.
Year ago I would have paid a pile of money to have someone rebuild one for me.
I could not find any shop anywhere to do so. This reasons given for this are because:
1. 004 parts are rare or unobtanium (not valid to me because I had all parts needed).....
2. there were numerous special VW jigs for measuring main gear stack tolerance and at least three special tools for adjusting the differential.....and they are unique to the type 4....so no one has them (valid)
3. None of these guys....Long, Rancho...you name...had ever been inside one. (valid)
I have been fully through at least 6 of them now. It took very little in cost...just time and thoughtful disassembly of the first two I did....to adapt dial indicators and micrometers to measure what was needed for differential and main gear measurements.
All else is similar to other VW types....inspection of synchro wear, checking R&P Fit with dye etc etc.
The $500 or so I spent on tools that I needed....and use in many other places...is still less than it would have cost me for a full rebuild if someone else had done it for me.
If you are willing to spend the money for a rebuild.....for about the same money you can buy the basics and make your own jigs (when possible)...and you are not in a hurry. Ray |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Mon Nov 10, 2014 12:25 pm Post subject: |
It takes less tools and time to do a vw trans than an engine. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Nov 10, 2014 1:07 pm Post subject: Re: Can you built trans at home? |
langan wrote: |
It depends on what you have and how you are trying to make a FF. Are you just trying to change the ring and pinion to a 3.88? Or are you changing gears sets? Is this a swingaxle or IRS? Some only require simple changes. Others require you to change the entire diff and/or gear carrier. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
Posted: Mon Nov 10, 2014 1:39 pm Post subject: |
mcmscott wrote: |
It takes less tools and time to do a vw trans than an engine. |
yeah I agree but it all depends on the builder .... I think a experienced builder can do allot with almost no tools . there is allot of little tricks and especially knowing what to look for and how to make adjustments . I built my own and im no tranny expert in the sense that im not doing it day in and day out but I have messed around with them allot . it can be done ... _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
Posted: Tue Nov 18, 2014 9:41 am Post subject: |
If all the parts that fall out of the used tranny are all within specs, sure - you can most def make a decent OVERHAUL.
If you are talking REBUILD - you have to modify parts like cleanup the hubs coz the gears have eaten into it....clean up the faces on the gears themselves.
To do accurate cleanup on these you need a minimum of a decent lathe. The hubs are soft and can be cleaned up w/ just cutters. But the gears are hardened -will need a toolpost grinder. Or a flywheel grinder to grind out the galled areas.
You can also use a flat piece of glass and sandpaper to clean up the gear faces. But the hub faces are deep in the recess -how are you going to clean that up by hand??
To bring everything back to factory specs -which is what a rebuild is- will need good tools and machines.
If you just want to go thru it that is an overhaul, not rebuild. |
langan Samba Member
Posted: Tue Nov 18, 2014 9:58 am Post subject: |
Thanks guys I do have a machine shop and a sheet metal shop. I was mostly looking for where to get the tools and parts and know how to do trans. Just never see adds for trans parts. I will just buy one done and be at the mersey of the builder. |
EvileNV Samba Member
Joined: August 03, 2010 Posts: 161 Location: Boulder City, NV
WD-40 Samba Member
Posted: Tue Nov 18, 2014 8:00 pm Post subject: |
jfats808 wrote: |
Everything above, plus u need access to a hydraulic press. You'll need to build about 5- 6 gear boxes to make the purchase of specialty tools worth it. This also includes the "learning curve" or more popularly known as the oops factor. |
You know, that's actually not too bad... _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
Posted: Tue Nov 18, 2014 8:04 pm Post subject: |
It is odd that it says it will not work on late t-2's, the plate is drilled for t-2 and the pins are the same length as late t-1.
To the OP, 90 % of people on this site believe that the vw trans is made of some type of voodoo and will tell you to stay away and "pay a pro" to do it. That is fine, I build these things for a living, more than 1000 t-1 boxes alone. So should you pay me, or do it your self? You will need some specific tools, just as you do for an engine. And there may be some machining involved, just as if you were building an engine. It is not voodoo.
I would have a hard time listening to someone giving you advise on an engine build but telling you to stay away from a gearbox because it takes special machine work. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
mark tucker Samba Member
Posted: Tue Nov 18, 2014 8:05 pm Post subject: |
Ive rebuilt many trans at home,mostly automatic for racing,chevy/gm, ford&mopar. motorcycle&a few others&many rearends. I have yet to dive into my vw trans.mostly because I dont currently have room to do it(toomuch v8 racing shit in my shop) and of corse I dont have all the tools needed and dont know all the tricks needed to do it "right".I have 3 jigs thats it.so i still need to get a few other things and room to do it. all my v8 racing stuff is for sale including a new unfinished car and many trick engines and parts. when there all gone I can start doing a lot more on my stuff again. |
