djghia Samba Member
Joined: May 08, 2006 Posts: 179 Location: Springfield, MO
Posted: Mon Nov 10, 2014 3:11 pm Post subject: New Judson project |
I purchased a Judson this year at a swap meet. Unit is fairly complete and should be fine after a re-build. I have already talked with George about it and he has convinced me to do it myself. Honed the housing last week and it looks great. Next move will be to get a parts order submitted to George. Hope to have it done and ready to install on my '62 Ghia this winter. Ghia has a fresh 1200 with a big-bore kit and runs quite well. Dave J
_________________ 1962 Ghia vert
1971 Beetle
GROOVE member |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Mon Nov 10, 2014 3:44 pm Post subject: super |
Cool find, look like it could be fun |
Steve22 Samba Member
Joined: March 05, 2004 Posts: 1389 Location: the wild unknown
Posted: Wed Nov 12, 2014 8:16 am Post subject: |
Just my 2 cents worth, but you may be disappointed with the Judson on that big bore kit, It wasn't designed to fill more than the original 1200. _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Posted: Wed Nov 12, 2014 8:50 am Post subject: |
Steve22 wrote: |
Just my 2 cents worth, but you may be disappointed with the Judson on that big bore kit, It wasn't designed to fill more than the original 1200. |
That's true but the Judson's worst enemy is inflated expectation. Many try to overdrive the unit by fitting a smaller diameter blower pulley to spin it faster and quickly run into overheating problems.
If you're happy to accept any gains the stock unit will give then just bolt it on and drive...it will flow more mixture than a normally carburated big-bore but not as much as most usually expect.
If you're into problem solving (re: overheating) then give it a go...some have made some innovative modifications to cool the unit but I don't know how successful they have been. _________________ John.
djghia Samba Member
Posted: Fri Nov 21, 2014 4:26 pm Post subject: |
Parts order has been submitted to George. Housing has been cleaned and painted. Will have to come up with an air filter to use. Would like to do it without modifying the engine lid, but I do have a spare engine lid just in case. I don't have any crazy expectations about performance, really want to do this just to be different I guess! I do see people running them on motors larger than 1200, so I think it is a feasible option for my 1385. Besides, let's face it, any amount of power increase is just that, an increase! Dave J _________________ 1962 Ghia vert
1971 Beetle
GROOVE member |
djghia Samba Member
Posted: Mon Dec 01, 2014 8:33 am Post subject: |
Case and end plates have been painted and my parts order has arrived!
1971 Beetle
GROOVE member |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Mon Dec 01, 2014 11:30 am Post subject: |
Looks beautiful! _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
djghia Samba Member
Posted: Mon Dec 01, 2014 12:53 pm Post subject: |
George is an amazing resource. I was pleasantly surprised by the price of the Ampco, he also sent along a pulley key and a Judson ID badge which I had not thought about! Thanks George, nice to know there are still honest men of their word out there. Just got done painting the intake manifold, pictures later. Dave J _________________ 1962 Ghia vert
1971 Beetle
GROOVE member |
djghia Samba Member
Posted: Mon Dec 01, 2014 12:57 pm Post subject: |
Would anyone(John!) know what size to drill a jet out to for this Judson application. It calls for a 140, I have a 122.5 from a spare carburetor and could drill it out if I had an idea of what size to make it. Don't mind buying a new one of the correct size if I need to, but why not try to drill one out! Dave J _________________ 1962 Ghia vert
1971 Beetle
GROOVE member |
djghia Samba Member
Posted: Mon Dec 01, 2014 1:33 pm Post subject: |
You are correct! For some reason I had remembered a 140 instead. May still try to drill it slightly larger as an experiment. Dave _________________ 1962 Ghia vert
1971 Beetle
GROOVE member |
djghia Samba Member
Posted: Mon Dec 01, 2014 3:36 pm Post subject: |
Intake with fresh paint as promised.
1971 Beetle
GROOVE member |
djghia Samba Member
Posted: Tue Dec 02, 2014 2:45 pm Post subject: |
Rebuild is complete! Went together nicely with no issues. Can't wait to get it on and running this winter.
1971 Beetle
GROOVE member |
oldturtle22 Samba Member
Joined: March 22, 2012 Posts: 14 Location: Brisbane, Australia
Posted: Sat Dec 06, 2014 5:26 pm Post subject: |
Great work. Interesting to see your performance figures!! |
djghia Samba Member
Posted: Tue Dec 16, 2014 4:18 pm Post subject: |
We shall see!! Dave J _________________ 1962 Ghia vert
1971 Beetle
GROOVE member |
djghia Samba Member
Posted: Mon Jan 19, 2015 4:16 pm Post subject: |
Have spent some time trial-fitting the Judson. Came to the realization that while I might make it work with a spacer under it to clear the alternator, it made more sense to put a generator back on. Traded my alternator for a good generator and regulator. Clearance issue resolved!
Also had to modify the carb linkage arm to work on my PICT 30, slot for throttle shaft had to be welded up and moved 90 degrees.
1971 Beetle
GROOVE member |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Tue Jan 20, 2015 7:42 am Post subject: |
For the final fitment you may want to use some gasket-cinch or pertronix aviation on the hardware to your judson.It will probably leak if you don't.Also , on the bottom of the judson there is a plug with a slot for a screwdriver.If you take the plug out you can fit a brass fitting for a boost gauge. Pain in the ass to run the vacuum line, and the line will probably cost more than the gauge but it's fun to have.
Keep the updates coming, I don't know about others but I love reading this stuff.
What about the generator outer pulley piece ?Do you have the judson one . if not you might have to shave yours down if it makes contact with the belt. I also had to make do with one bolt to the coil bracket instead of two since I had to turn the coil vertical to clear the throttle linkage. I just used some locktite and cinched it real tight and it worked. |
djghia Samba Member
Posted: Tue Jan 20, 2015 9:24 pm Post subject: |
End caps have been sealed with gasket sealer. Will no doubt use some on all gasket surfaces for final assembly. Need to get some copper washers for carb mount nuts as well as nyloc nuts for same area to get a good seal. I also only have one coil mounting bolt, I see in original installation instructions that this was the official method. Good question about belt clearance on the generator pulley, I shall watch for that as I get to the belt install. Need to come up with an air cleaner for this, hate to spend the money for an official one, will look at some other options first. I do have a "hood scoop" and spare engine lid to use as I fine tune. Waiting on my carb jet from George Folchi to arrive, then just have to have a slight pulley modification done at the machine shop for the crank drive. Thanks for your interest and information. _________________ 1962 Ghia vert
1971 Beetle
GROOVE member |
djghia Samba Member
Posted: Mon Mar 02, 2015 3:30 pm Post subject: |
Has been a busy few weeks. After several trips to the machine shop, I finally have the drive pulley situation squared away. Went to the local parts emporium and got belts for it and after a short time had everything installed.
Yes, I started it up today and it sounds great! Still have some fine tuning to do and the air filter and hood scoop situation to deal with. Ended up going with the real thing for a scoop and I think a later model Ghia elbow and after market filter will work for me.
Thanks Rich for your willingness to supply me with one! It will soon be painted black to match the car. _________________ 1962 Ghia vert
1971 Beetle
GROOVE member |
