Stock66 Samba Member
Joined: June 30, 2014 Posts: 120 Location: Pittsburgh, PA
Posted: Fri Nov 21, 2014 9:50 am Post subject: |
Well I ended up just mounting the cover I had over the round hole, I had to use a couple extra screws, I will paint the screw heads black and hopefully it won't be too noticeable.
Not my favorite thing to do, as I want this cars base to be very original, but I think this is an exception as making more cuts may cause unnecessary rust later on. As far as the left access hole or I should say the non-existent hole, I've decided to leave it alone and uncut...
What do you guys think?
Now I need to get the dummy brake fluid reservoir mounted by making a strap and screwing that in and my front end resurrection should be complete.... |
Posted: Fri Nov 21, 2014 9:58 am Post subject: Deck Lid assembled |
We also got the deck lid put back together.
It really is looking different, as when we got the car all of the rubber had been painted white when the car was resprayed at some point a bright white.
As well as some of the dash, It's starting to look like a VW again, Plus I feel things are getting accomplished as the parts sitting around the garage are dwindling down.
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Sat Nov 22, 2014 8:19 am Post subject: |
Real nice! Lotta work? |
grandpa pete Samba Member
Posted: Sat Nov 22, 2014 10:01 am Post subject: |
I got a chuckle out of the "parts dwindling down " comment....I finally have a usable patio after a year of Type6 project......
GREAT feeling of accomplishment.......
Now you can start thinking of the next project
57 oval !!!
note : be careful assembling the dash vent ; the lower piece is NOT reproduced ; I put vasaline on the plastic so it would snap together easier..
.The top piece is available from WW
Did you put hose clamps on the fuel filter and hose out of the tunnel ?...{ earlier photo } _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Sun Nov 23, 2014 2:41 pm Post subject: |
Grandpa Pete- the first thing we did when we got the car was get rid of the plastic (half melted) fuel filter in the engine bay, found a nice metal one and replaced all of the fuel line with new stuff. I had some spring tension clamps that fit just right and put those on even though it may not be needed, I prefer a little something extra.... |
Posted: Tue Nov 25, 2014 10:52 am Post subject: saga continues |
Last weekend we worked on cleaning up the front end, access cover, dummy brake res.( just need to fabricate a strap), hood release tube.
Instead of welding the hood release tube, which got pretty mangled in the accident, we straightened it as best we could and attached it to the body with some clips.
Finished out GT Mat installation as well, works much better when heated with a hair dryer for a few minutes
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Tue Nov 25, 2014 12:46 pm Post subject: |
Great Progress, but ive got a few suggestions.
1. Did you get rid of that urethane steering coupler and go back to a stock one? I made that mistake on my dune buggy and when it gives way, you have absolutely no steering, as compared to the original clothand rubber type, which still allow you to get the car outta the road ( safety)
2. That bowdens tube needs a curve in it
other than that, great job
(stole the pics from your gallery)
Great job otherwise
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
Posted: Tue Nov 25, 2014 1:08 pm Post subject: |
Bret
Yes I did buy the urethane one to replace the original. I didn't even think of that but you would be right when it breaks. I'll keep this one for now and definitely replace with og in the future. I really appreciate those kind of comments.
And as far as the Bowden tube goes are you talking about the clutch or throttle?
I did buy the throttle cable tube that goes between the chassis and engine tin..
The clutch tube does have a slight bow to it( it's flexible) the picture may be deceiving. |
Posted: Tue Nov 25, 2014 1:22 pm Post subject: |
The bowden tube is the flexible tube that the clutch cable is in. You should have a pronounced bend in it.( like this )
you can add spacers to the end of the tube that fits in the transmission bracket so that the tube will have the proper bend. without th bend your clutch function could be kinda catywampus
1959 beetle
1962 Karmann Ghia
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Tue Nov 25, 2014 6:55 pm Post subject: |
Bret's right. The washers at the end of the Bowden tube will give you a good "bend" in your tube. Here's what mine looks like I recently replaced:
You can also do a forum search and find TONS of threads on this. _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Thu Dec 04, 2014 1:15 pm Post subject: |
Did a little more work.
Getting the hood aligned / mocked up to be sure the release mechanism works. What a PITA. I had to crawl into the trunk area to remove the latch mechanism a couple of times because it wouldn't release.
Posted: Thu Dec 04, 2014 1:30 pm Post subject: |
I also scored a set of door handles and ignition with matching key to replace the beat up old ones.
The ones I got are not exactly the same, as they are not "wrapped"
From what I gather the stainless wrapped came later in 66...is it still correct if I use the solid ones I picked up?
One that came with the car is at the top of picture.
Cleaning lock mechanisms and replacing the weak springs, they felt much softer than the ones I had, didn't like it so I swapped springs.
Posted: Thu Dec 04, 2014 1:36 pm Post subject: |
polished up the ashtray and dash pieces....very tedious...drill with polishing wheel works great though.
Like a mirror!
What color are these knobs? ivory or grey ?
offshores Samba Member
Joined: February 08, 2012 Posts: 1085 Location: So Cal
Posted: Thu Dec 04, 2014 4:02 pm Post subject: |
The project is lookin good. Definitely grey. |
Posted: Thu Dec 04, 2014 11:22 pm Post subject: |
Even though the knobs are practically the same color as the car (Pearl White)? |
Posted: Fri Dec 05, 2014 7:53 am Post subject: |
Based on your pics, it looks grey to me. The ivory is more yellow.
Here's a pic from shortride's gallery. Ivory window squirter button and the rest are grey.
Posted: Fri Jan 02, 2015 2:50 pm Post subject: |
With the holidays we haven't had much free time on our hands. As much as I'm enjoying working on the body reassembly we have to get he chassis ready to accept the body at some point soon. So we jumped back to it.
We managed to get the front suspension and steering finished and reassembled. rebuilt the steering box. We had to get a tie rod from the salvage yard since I found out the hard way our inner tie rod end was crimped on and since we already had all of the new ends I didn't want to have send them all back to buy a complete assembly.
Front Complete
Hell of a time with the anti-sway bar, I hope its correct.
Posted: Fri Jan 02, 2015 2:57 pm Post subject: |
And we got the transmission and axles out in one piece, It was definitely a lot easier than I had imagined it to be.
Now we get to start cleaning this all up and reassembling, I have a new rear seal kit and brakes just waiting to be installed.
trying to decide if I should replace the e-brake cables....?
We will be busy this weekend
Posted: Fri Jan 02, 2015 4:12 pm Post subject: |
Nice progress! Did you use a kit from somewhere to rebuild your steering box? I have yet to find one anywhere.... _________________ .
