shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
Stock66 Samba Member
Joined: June 30, 2014 Posts: 120 Location: Pittsburgh, PA
Posted: Fri Feb 06, 2015 1:06 pm Post subject: |
We used POR-15 for the chassis. The underneath had been very heavily under coated probably by the dealership and was in very good shape, so we kept with that on the bottom and gave it a fresh top coat. _________________ 1966 Beetle - Our Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=611939 |
bugmandave Samba Member
Joined: December 30, 2005 Posts: 642 Location: Illinois
Posted: Fri Feb 06, 2015 5:59 pm Post subject: |
the padding in the rear quarter panel might hold moisture from condensation and cause problems. I'd be hesitant to put it in there. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
'71 Westfalia campmobile tourist delivery
January '59 SWR panel
'63 Karmann Cabriolet L54 Poppy Red |
Posted: Thu Feb 12, 2015 12:11 pm Post subject: |
Got one side finished up in the rear, new seals and brakes.
Old cruddy stuff
Wire brushed and painted the backing plates
Drivers side complete, I put it back to how it was, but if anyone notices something out of place please let me know. _________________ 1966 Beetle - Our Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=611939 |
Posted: Tue Feb 24, 2015 11:44 am Post subject: Body On |
We seem to have accomplished a good amount last week.
wrapped up the chassis work (for now, until we decide what to do with the suspension as far as ride height) rear brakes, shock front and rear. then this past weekend had a body lifting party and mated the body back up with its long awaited pan.
Finally!
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Tue Feb 24, 2015 11:53 am Post subject: |
Props! It's clean. |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Tue Feb 24, 2015 4:21 pm Post subject: |
Nice! The home stretch! _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
johnr156 Samba Member
Joined: April 06, 2013 Posts: 144 Location: Dixon, Ca.
Posted: Tue Feb 24, 2015 7:59 pm Post subject: |
Did you happen to have to motor in when you dropped the body on? I considering doing my 66 that way and was curious if it made it more difficult. |
Posted: Tue Feb 24, 2015 8:15 pm Post subject: |
johnr156 wrote: |
I did mine with the engine in and everything hooked up and tested before body went on. It's way better than doing all that with the body in the way. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Tue Feb 24, 2015 11:40 pm Post subject: |
Stock66 wrote: |
Bret2094 wrote: |
Great Progress, but ive got a few suggestions.
1. Did you get rid of that urethane steering coupler and go back to a stock one? I made that mistake on my dune buggy and when it gives way, you have absolutely no steering, as compared to the original clothand rubber type, which still allow you to get the car outta the road ( safety)
2. That bowdens tube needs a curve in it
other than that, great job
(stole the pics from your gallery)
Great job otherwise
Bret |
Okay Bret, How does it look now?
got the trans all cleaned up and mounted again.
That's straight transmission and pan porn right there, Looks great
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
Posted: Wed Feb 25, 2015 12:02 am Post subject: |
johnr156 - No we didn't have the motor ready yet, although I wanted do it that way, we needed to move forward with the body to make room in our shop. We took the body off with the motor in that chassis so I imagine it would definitely be easy to put back, but you are probably right that its a tight fit trying to align it all back up...
It should be interesting when we have to jack the car up and slip the engine in from under the car, But I imagine since that's how people have done it for years it must be okay..
I'll let you know how it goes _________________ 1966 Beetle - Our Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=611939 |
peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
Posted: Sat Apr 11, 2015 1:04 pm Post subject: |
So we are in the home stretch, but we are having some electrical issues.
When we apply the brakes the brake lights do this;
Left rear lights correctly, right rear lights correctly, but dim and the front right turn signal lights up....weird combination
I've checked the grounds and will recheck again.
Anyone ever have something like this happen? _________________ 1966 Beetle - Our Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=611939 |
mukluk Samba Member
Posted: Sat Apr 11, 2015 1:55 pm Post subject: |
Stock66 wrote: |
Anyone ever have something like this happen? |
Sounds like the right rear lamp is using the right front lamp as a ground via the turn signal or parking lamp wire. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sat Apr 11, 2015 9:25 pm Post subject: |
Mukluk, that's exactly what was happening. Thanks for pointing me straight.
I ended up cleaning up all ground points on the rear taillights, much brighter and better.
Now if I can get a 9 pin flasher box to work, I've been through 3 used ones and no luck.
Has anyone updated their wiring configuration with newer flasher relays etc.?
Thanks in advance. _________________ 1966 Beetle - Our Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=611939 |
Posted: Sun Apr 12, 2015 9:35 pm Post subject: |
okay, taillights are working correctly, now the only problem is when I use the turn signal switch and use the left blinkers its good works as it should, when I use the right blinkers I blow the #8 fuse....ThiNk i'M at mY WiTs end..help! _________________ 1966 Beetle - Our Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=611939 |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Mon Apr 13, 2015 12:32 am Post subject: |
About rear brake:
Have you tried to put the upper spring upside-down? It is not symmetrical, now it is 'curved', if you turn it, so its arms are at top instead of bottom, you'll have it perfectly alinged with the equalizer bar, without bending. |
Posted: Mon Apr 13, 2015 8:04 am Post subject: |
I've figured out my shorting issue, turns out it was my right rear reflector. Although it is brand new, I saw a small area where the top bulb insulator was worn through. So I opted to put an OG that I just so happened to have that wasn't broken. Worked like a charm, 10 blown fuses later and after tediously going though everything on the turn signal switch...we are good to go.
Now I just need to get a good 9 pin flasher box that won't brake the bank, or I think I'm going to use a DPDT relay, it's not original but I think newer electrics have a time and place to be warranted. _________________ 1966 Beetle - Our Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=611939 |
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Mon Apr 13, 2015 8:28 am Post subject: |
Stock66 wrote: |
So while the tank was out we cleaned it up and got some POR-15 on it. the PO apparently replaced the OG one probably when the front was hit with this one. The inside was pretty clean and not rusted so just needed cleane dup on the outside and put a new fuel outlet on.
That looks great witch POR is that you used. Is it just the paint? |
Posted: Mon Apr 13, 2015 9:37 am Post subject: |
Dake,
Thanks for the compliment!
It's gloss black POR-15. If you haven't used it before be very careful, cover your skin. It's very very thin and self levels very well. _________________ 1966 Beetle - Our Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=611939 |
