GTV Samba Member
Posted: Thu Nov 13, 2014 8:33 am Post subject: |
If you actually do have 58cc in the chambers and only 7.2:1, you have a massive .166" deck. That needs to come down. .050" will give you the 9:1 that you're after. Going to 9:1 will make a massive difference. BTW, 44x37.5 valves are huge for what you're doing.
If swapping the cam isn't in the cards right now I wouldn't worry about it too much. It will wear out the lifter bores, but you can always have them re-bushed when you are ready to split the case. It won't turn your case to junk.
What carbs and exhaust are you using? _________________ EMPI Power Rules! |
Posted: Thu Nov 13, 2014 8:38 am Post subject: |
nobody can give accurate cam recommendations until you tell us what carb(s) and exhaust you have. We are not mind readers. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
jz56oval Samba Member
Joined: September 03, 2007 Posts: 375 Location: bay area
Posted: Thu Nov 13, 2014 8:49 am Post subject: |
I have Weber redline 40's. and a Vintage speed exhaust. That deck height is huge if you are correct.
Would I need to check each cylinder for deck height or just one? |
Dale M. Samba Member
Posted: Thu Nov 13, 2014 8:53 am Post subject: |
jz56oval wrote: |
You need to pull head and measure deck height and cc head before making any decision (assumption) on the "fix"... I would personally check then all....
Posted: Thu Nov 13, 2014 8:59 am Post subject: |
Is measuring cc easy. should I measure it even if the maker shows it on the website?
Thanks |
GTV Samba Member
Posted: Thu Nov 13, 2014 9:09 am Post subject: |
Measure everything.
Carbs are too small, heads are too big... Pull the heads off and see if what you think you have is what you really have. _________________ EMPI Power Rules! |
hooker Samba Member
Joined: October 07, 2004 Posts: 261 Location: Bend, Oregon
Posted: Thu Nov 13, 2014 9:17 am Post subject: |
GTV wrote: |
Measure everything.
Carbs are too small, heads are too big... Pull the heads off and see if what you think you have is what you really have. |
I would run a compression test before I did anything. Better to have some facts to work with than guessing. The builder may have done that wrong in calculations. _________________ 2007 NHRA Division 6 Finals Champion air cooled Rabbit P/U rear engine compact/import class, 13.32 sec 1/4 Woodburn, Oregon
Pauter Big Block VW 2610 cc turbo mid engine roadster 9.69 sec @ 147 mph 1/4 PIR Oregon
I spent most my money on women and VW race cars. The rest I wasted. |
Kfeher2000 Samba Member
Joined: November 03, 2014 Posts: 38 Location: Portland, OR
Posted: Thu Nov 13, 2014 10:53 am Post subject: |
I had a similar situation with a 1904cc.
It was 7:1 and I took the heads off, reconfigured the barrel spacers to make it 8.7:1 (a weekend project)
Best thing I could have done
It runs stronger, cooler and gets better MPG
Gene Berg's CR recommendation of 7:1 is out dated and no longer relevant with today's fuel |
Posted: Thu Nov 13, 2014 11:08 am Post subject: |
Kfeher2000 wrote: |
What do you men barrel spacers? Did you remove them or add? |
GTV Samba Member
Posted: Thu Nov 13, 2014 11:20 am Post subject: |
Barrel spacers are placed under the cylinders (barrels) to get the desired deck height. You'll have to pull the motor first to see what you're was built with. _________________ EMPI Power Rules! |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Thu Nov 13, 2014 11:33 am Post subject: |
jz56oval wrote: |
Kfeher2000 wrote: |
This will be your new best friend
http://www.cbperformance.com/v/enginecalc.html
I used a combination of barrel shims and copper head gaskets to get the desired deck height.
Pull the motor, use an engine stand...and take your time.
If you never pulled a VW engine down before, do plenty of research first but don't be afraid to tackle it. |
Posted: Thu Nov 13, 2014 11:36 am Post subject: |
Thanks for all the info and help guys. Ill get to it when I have time. Would it be wise to make the heads lower cc's or leave at 58cc? |
Posted: Thu Nov 13, 2014 11:38 am Post subject: |
If you never pulled a VW engine down before, do plenty of research first but don't be afraid to tackle it.[/quote]
I have pulled my engine plenty of times. Just havent taken it apart or removed the heads. Shouldn't be hard. Just time.
Just by looking at the calculator with what I think I have, ill need a DH of 4.08 or 4.13
Now I cant wait to pull it out and check |
hooker Samba Member
Posted: Thu Nov 13, 2014 12:42 pm Post subject: |
Max Welton wrote: |
jz56oval wrote: |
Is measuring cc easy. should I measure it even if the maker shows it on the website? |
Yes.
And a compression test won't tell you anything about the compression ratio.
Max |
If you say so it must be true.
========================== _________________ 2007 NHRA Division 6 Finals Champion air cooled Rabbit P/U rear engine compact/import class, 13.32 sec 1/4 Woodburn, Oregon
Posted: Thu Nov 13, 2014 3:35 pm Post subject: |
So I'm guessing that the shims are between the block side and not head side? |
Posted: Thu Nov 13, 2014 3:48 pm Post subject: |
Barrel spacers go between the case and the cylinders. This increases deck-height by raising the cylinder, lowering the compression ratio.
hooker wrote: |
Max Welton wrote: |
Max |
If you say so it must be true. |
It seems like compression test results should reveal something about compression ratio, right?
Try this: My last compression test numbers were all between 100 and 110. What do you now know about my compression ratio?
How about if I tell you it's a 1776 running an Engle-100 cam at 7500'. Any help? No?
How about if I tell you it cranks at 250 rpms? Anything?
Problem is there are too many other things that affect the readings much more. Like the condition of the rings and valves.
Max _________________ 1967 Type-3 Fastback
MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Thu Nov 13, 2014 4:05 pm Post subject: |
jz56oval wrote: |
Shims between the case and cylinders will tighten your deck # _________________ 1974 Thing |
Posted: Thu Nov 13, 2014 4:30 pm Post subject: |
Was wondering what is a good gasket sealant? What is on there now is a red/orange color. |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Thu Nov 13, 2014 4:47 pm Post subject: cr |
Just pull the engine, pull the heads and see what you have. Speculate all you want. Your gonna end up doing more than you think once your that far into it anyway |
