Stuart Maingot Samba Member
Joined: December 13, 2009 Posts: 240 Location: Trinidad West Indies
Posted: Thu Nov 13, 2014 12:10 pm Post subject: epoxy primer with matt clear. |
Have completed body work and took car down to bare metal, epoxy primed then did light filler work and putty and then smoothed all over and did a final of 2 coats of epoxy primer.I used Sikkens EP II grey. The car is now ready for paint and I planned to use a matt grey anyway but I like the look of the matt grey primer and would like to know if it would be reasonable to just use a matt clear coat over this and leave it at that. Is there any reason that the epoxy primer with matt clearcoat would not standup to tropical elements?
Thanks for any advice. |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Thu Nov 13, 2014 1:40 pm Post subject: |
That sounds like you need to contact the paint manufacturer on that. I have used the primer as a base & cleared over it, but that was for the movies & it only needs to last until they call cut. _________________ I think he meant "rare", as in "not well-done" |
Posted: Fri Nov 21, 2014 7:59 am Post subject: |
I suppose that is the best advice however my local dealer wants to sell paint so they are not giving me any explanation why it would not work except to say NO.
So I will be trying this by applying a final reduced coat of the epoxy primer as a sealer and then shoot the matt clear over. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Nov 21, 2014 8:40 am Post subject: |
Spray 3 thin coats of clear on it in one day and call it finished! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch Samba Member
Posted: Fri Nov 21, 2014 11:58 am Post subject: |
Stuart Maingot wrote: |
Your paint "jobber" isn't giving you any info, not because he wants to sell some paint, but rather the epoxy doesn't have any UV stability in it (why it must be painted). But, since you're covering it with clear, you MIGHT be able to get away with just clearing the primer (it's technically sealed). I'm not saying you can do it, because it MIGHT not hold out colorwise under the clear. Without the clear, the epoxy will chalk due to the UV rays from the sun.
IF you really like the color of the primer, then I'd either do a "spray out" card, and have the color custom mixed. Or, I'd take the car to the paint supply, and have them "read" the color, and custom mix some paint for it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Nov 24, 2014 9:50 am Post subject: |
Your points wrt the UV stability is well noted. I guess there is no shortcutting here without risk. I may just have to go the regular route of base /clear over the epoxy. Still deciding..... |
