oconnell Samba Member
Joined: September 04, 2006 Posts: 214 Location: waynesville, missouri
Posted: Fri Nov 14, 2014 12:57 pm Post subject: Type 4 bolt for engine |
I need to buy a bolt I lost for my type 4 engine.
It is the case through bolt that holds the oil pickup in place.
What are the deminsions of the bolt and I can get a new one.
thanks |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Fri Nov 14, 2014 4:16 pm Post subject: |
I will measure one this evening. Ray |
Posted: Fri Nov 14, 2014 5:21 pm Post subject: Type 4 |
Raygreenwood I thanks you for measuring
I really appreciate your help. |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sat Nov 15, 2014 4:50 pm Post subject: Oil Pickup Bolt |
The Oil pickup Bolt is 77 millimeters in length and this includes the bolt
head.
It is a special bolt since the unthreaded portion is thicker in order to fit the eye of the pickup..up
Be sure to start this bolt BEFORE installing the strainer and plate so you can
wiggle the pickup as you thread the bolt that way the threads in the case will not be screwed.
This is the 1st bolt to Install when assembling these type-4 engines.
Torque to 14 ft. lbs. with sealer on the Copper washer.
If you have no other choice in finding the correct bolt make sure the one you
buy is of good quality and is only threaded approx.:24 mm up the shank. _________________ V.W.owner since 1967 |
Posted: Sat Nov 15, 2014 5:15 pm Post subject: Re: Oil Pickup Bolt |
old DKP driver wrote: |
head.
buy is of good quality and is only threaded approx.:24 mm up the shank. |
Thank you sir!....I was having a hard time getting to mine to measure....snow tire day.
As for the unthreaded shank portion, a normal 8mm bolt with unthreaded shank in the right place will fit fine.
I had to replace one a while back Just be sure to use some sealant under the head. Indian head works great for this.
I also use Schnoor type ribbed bellville lock washers religiously on case bolts....especially this one. Ray |
Posted: Sun Nov 16, 2014 5:15 am Post subject: type 4 |
thanks all
lots of good info the books don't tell or know |
