grandpa pete Samba Member
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Sat Nov 15, 2014 4:11 pm Post subject: |
Anything can be done with enough cutting and welding, but far easier to just get 1966 or 67 doors. Someone will trade you. _________________ In Stereo, Where Available! |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Nov 15, 2014 4:40 pm Post subject: |
There was a recent post here about an early '64 with late '64 1/2- door latches. They worked fine to latch the door, but he couldn't lock or unlock from the inside with the remote controls. Something about the remotes didn't have enough throw, or the operating arms being too long or short.
I'd say if you swap in all the parts from your '66 doors, it should work same as a late '64. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon Nov 17, 2014 9:13 am Post subject: |
Using the all the door lock and handle parts from the 66 doors.. placed in the 63 doors...
Should work... with little effort.
Eric&Barb wrote: |
Anything can be done with enough cutting and welding, but far easier to just get 1966 or 67 doors. Someone will trade you. |
67 doors take an entirely different latch mechanism.. not interchangeable to pre 67 bodies.
Plus.... GP's project.. needs the smaller windows...
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sun Nov 23, 2014 9:17 pm Post subject: |
look on side of door handle for key code. it may be SG or other. code will be stamped on both 63 (example) and 66 (example) door handles. code will be SC### or SG### for example. it will be stamped on side of removable piece and may be lucky to find both same code. if early 66 the buttons with lock cylinder will fit in 63 button. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
