dnath56 Samba Member
Joined: October 02, 2014 Posts: 7 Location: Fullerton
Posted: Sun Nov 16, 2014 10:28 pm Post subject: Stock radio for 1956 vw bug |
Any sites other than here good for finding stock radios for a 1956 vw bug? I found the one I need on here but it doesn't work and would like to find a working one. Any advice or information is appreciated |
Danwvw Samba Member
Posted: Mon Nov 17, 2014 12:01 am Post subject: |
Those old motorola volumatic radios will need new vacuum tubes and capacitors to work! I would take it to a Electronics Repair Shop. They are pretty rare in working condition these days. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Mon Nov 17, 2014 5:07 am Post subject: |
It doesn't matter to me if it works or not. It would be more just for looks. I think mine had a sapphire from where the holes are. Just having a hard time finding one |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Posted: Tue Nov 18, 2014 9:55 pm Post subject: |
Stock radio would be a block off plate in the dash.
Lots and lots of radios were sold by the VW dealerships and by any aftermarket supplier of radios.
Pick a radio you like the looks of or has the band/s you want that was manufactured the same year or even a few years later. Get the best condition exterior wise and complete as possible. Then send it off to get it repaired, or of course get one that has already been repaired. _________________ In Stereo, Where Available! |
djcvw Samba Member
Joined: September 10, 2013 Posts: 67 Location: California, USA
Posted: Fri Nov 21, 2014 11:46 am Post subject: |
Does anyone know what brands were available for the '56 beetle?
I have a Sapphire I in the garage, not sure if it works or not. I'd have to dig it out. But I'm not sure if this was for the '56 or later year. My '56 came with a Motorola Big M. |
Posted: Fri Nov 21, 2014 1:35 pm Post subject: |
Got to remember that these VWs were often bought new without a radio. Later when the 1st owner paid off the last for his VW, without a monthly payment the next month or two it was easy to save up and buy a radio.
Plus when the old VW was sold or traded back into the local VW shop, the dealership would spruce up the interior by replacing front seat upholstery with new, driver door card with new, and often enough to install a new radio. So if you could only afford a no frills new VW, there was the used VWs with frills for less $$$.
Have seen 1961 instructions on how to install all transistor radio in 1956 dash.
Sapphire came out in 1960.
Check out the "Archives" button at upper right and hover your mouse cursor over it. A list will pop up there. Left click on the "Literature" and on the next web page scroll down to "Miscellaneous" column. The "Radio Brochures" there is OK, but the "Accessory Brochures" just above is a bit better. Pick your year and a few years later and brows around.
Here is a previous post, found thru a search for "1956 VW radio":
http://www.thesamba.com/vw/forum/viewtopic.php?p=2158078 _________________ In Stereo, Where Available! |
djcvw Samba Member
Posted: Fri Nov 21, 2014 3:11 pm Post subject: |
Eric&Bard - thanks for the information. Interesting that you attached that previous post. I did a search before I posted and could only find this one. Anyway, great information.
I will pull the Sapphire out of the garage and probably post it for sale. I won't be using it any time soon. |
Posted: Fri Nov 21, 2014 5:45 pm Post subject: |
No problem!
Do also keep in mind that VW dealers would also install radios from previous years that were just sitting on the shelf. So do check out the 54-55 radios that might strike you as great looking or have radio bands you would like to have.
Plus due to competition from the USA, most Euro automobile manufactures worked together to standardize the electrical systems so same colored wires were used. Plus the dash opening in the Euro automobiles were standardized so a Euro made radio will fit many other Euro made automobiles. EG Porsche used same Euro radios as VW, just changed the face plates, knobs, and the face with green radio numbers to match the other Porsche dash gauges. _________________ In Stereo, Where Available! |
Posted: Fri Nov 21, 2014 6:11 pm Post subject: |
Here is a great web site:
http://www.gutefahrt.com/
Left click on the "Radio" on the left side of the screen.
Next web page it takes you to, left click on the particular radio brand you would like to explore and then scroll down thru the info.... _________________ In Stereo, Where Available! |
wimkever Samba Member
Joined: July 16, 2004 Posts: 411 Location: Holland (the Netherlands)
Zundfolge1432 Samba Member
Posted: Sun Nov 23, 2014 12:12 pm Post subject: |
Do a little search for nick stokes dub tunes. He has all the radios and does restorations . The Motorola you are talking about is known as "the big M " |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1896 Location: San Fernando Valley, CA
