55bundt Samba Member
Posted: Sat Jan 24, 2004 10:51 am Post subject: Barndoor cargo floor compared to later floors |
when replacing the cargo floor in a barndoor, will the floor have to be barndoor only or can a late 55 and later cargo floor work? I know the rear firewall / luggage area is different but my concern is the floor that rests above the belly pans. Thanks |
vwjosh6070 Driveway Camper
Joined: August 24, 2003 Posts: 2802 Location: not camping...
Posted: Sat Jan 24, 2004 12:58 pm Post subject: |
good question. try asking that in the barndoor mafia thread. _________________ josh, AKA "the infamous josh"
1973 Transporter "Floyd"
****Wheres my old bus?! 1967 Montgomery Ward Camper****
KI4MXO |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Sat Jan 24, 2004 1:05 pm Post subject: |
The overall stamping of the sheet metal is different, the flat strips where the middle seat bolt down are in different places, ofcourse the area above the shift coupler, the ribs run straight into the bulkhead, the outter sill by the cargo door is different.....If you don't care about correctness just slap a later one in there.....most peple wouldn't be able to tell if you did a good job. |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Sat Jan 24, 2004 1:06 pm Post subject: |
The only differance I think there can be is where the seat base mounting plates are.
I have a 54 kombi, and strangly there are no seat base mounts? so it seems I have a panel van floor.
If your just replacing sections I would try to cut some sections out of a bus in a scrap yard as the profile of re-pro floor panels in not the best. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Barndoor Mafia Il Capo
Joined: August 23, 2001 Posts: 6194 Location: EUSKAL HERRIA
Posted: Sat Jan 24, 2004 5:12 pm Post subject: |
campingbox wrote: |
Brick Top beat me to the punch, but you mentioned that you have an early 55 floor section? As long as it's an early 56 bus that holds the 6 leg middle seat, it's the same! My old 55 Kombi, I think it was an April of 55? Right Linda? And BBJ's 56 deluxe had it also.
Laydo |
BUCIOBATISTI Samba Member
Joined: April 17, 2002 Posts: 6956 Location: San Diego, California, USA
Posted: Sun Jan 25, 2004 12:26 pm Post subject: |
Yep, April '55, same floor as Barndoor. All Wolfsburg Buses would have the same floor. _________________ Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings! |
Posted: Sun Jan 25, 2004 12:28 pm Post subject: |
BUCIOBATISTI wrote: |
Yep, April '55, same floor as Barndoor. All Wolfsburg Buses would have the same floor. |
Hey Linda's back!!! EEEOOOOWWWWWW!!!!!!!!
Laydo |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Mon Jan 26, 2004 2:05 am Post subject: |
Why do I have a panel van floor in my kombi?
There are no seat base mounts! _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
bigbulli Samba Member
Joined: September 30, 2000 Posts: 575 Location: ENGLAND
Posted: Mon Jan 26, 2004 4:43 am Post subject: |
I have a set of later Brazilian floor halves for my BD, apart from the stamping being different they definately fit. I also converted them from loading doors on the right to loading doors on the left. This was straight forward. _________________ 1954 Barndoor
1955 Oval |
Rusting Hulk Samba Member
Joined: August 20, 2002 Posts: 646 Location: Malvern UK
Posted: Mon Jul 12, 2004 12:57 pm Post subject: |
Has anyone got pics of the 'Wolfsburg' cargo floor. Cant seem to access Everett's from the above post.
Thanks _________________ 64 356 C Coupe |
Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1154 Location: San Tan Valley, Arizona
Posted: Tue Jul 13, 2004 4:02 pm Post subject: |
Thanks guys,appreciate it _________________ 64 356 C Coupe |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Tue Jul 13, 2004 5:15 pm Post subject: |
I just cut the whole rear cargo floor and doglegs out of an early 56 std micro to use on my 54. Now my question is what is the easiest way to remove the floor from the cross braces. Am I going to have to drill out every spot weld? _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Metalwizard Samba Member
Joined: October 21, 2003 Posts: 696 Location: Archdale, NC
Posted: Wed Jul 14, 2004 7:23 am Post subject: Floor |
Skim , yea or use them if they are in good shape, there are 2 welds per rib that touches the x beams, except for the front top hat i think and may be the rear top hat and they have 1 every time it dips. Get a good spot weld bit if you attempt it not the hole saw type, actually ya might oughta get several, those welds do not give up easy, later, oh and on the rocker thread i'll take some pics today and try to post tonite. later |
Merlin Samba Member
Joined: August 19, 2004 Posts: 2103 Location: South Africa
Posted: Mon Dec 02, 2013 8:32 am Post subject: |
EverettB wrote: |
[email protected] wrote: |
Why do I have a panel van floor in my kombi? There are no seat base mounts! |
Maybe it was purchased without rear seats?
Does it have M-code 13?
Interesting... |
My Kombi also seems to have been ordered without rear seats. We cannot find any traces of mounting points.
Short of getting a birth certificate, is there any other way to find out what options a barney was ordered with?
Am I right in assuming that the term "M-code" is used with some poetic justice in this context? I thought that term only came into play later on?
Thanks.
Nic _________________ the3rdrock.com - …musings, discoveries and postulating, by a restless itinerant in search of enlightenment.
iowegian wrote: |
People who are allowed to have signature lines annoy me. |
Posted: Mon Dec 02, 2013 9:45 am Post subject: |
Merlin wrote: |
EverettB wrote: |
Interesting... |
Thanks.
Nic |
I think you have to order the sheet...
M-code often refers to the plate but as far as I know the term M-codes is still correct before the plate existed. M=option.
I have seen someone post a photo of their front bulkhead where the M-codes were spray-painted on there, it was revealed by carefully media blasting that area. _________________ How to Post Photos
Merlin Samba Member
Posted: Mon Dec 02, 2013 9:56 am Post subject: |
Consider me educated.
Thanks Everett. _________________ the3rdrock.com - …musings, discoveries and postulating, by a restless itinerant in search of enlightenment.
iowegian wrote: |
