Art.b Samba Member
Joined: May 26, 2013 Posts: 62 Location: New Hudson,Mi
Posted: Mon Nov 17, 2014 7:45 pm Post subject: Any insight on these rods? |
Tore down an 82 stroke engine with a dms crank and found these rods.
Anybody know who made them? 5.3" length 1.815" rod bearing 3/8' bolts.
_________________ THE MOTOR CITY
raymon covey Samba Member
Posted: Mon Nov 17, 2014 7:56 pm Post subject: |
rabbit rods |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Mon Nov 17, 2014 9:33 pm Post subject: |
Maybe rabbit. Here's specs of the rabbit bearing
modok wrote: |
here's spec for "EH" or "EJ" vw, like a 1980 model
ACL pn: 4B1636 OR clevite PN: CB1017P
crank
45.949/1.8090
45.969/1.8098
housing
49.000/1.9291
49.017/1.9298
max thickness
1.506/0.0593
clearance
.018/.0007
.082/.0032
width
19.00/0.748
the corvair bearing is narrower
Clevite Rod Bearing CB-584P
crank1.7990/1.8000
thickness 0.0620
housing 1.9247/1.9252
width 0.6840 |
3/8 bolts you can assume 45 ft-lb torque until further notice |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Mon Nov 17, 2014 10:22 pm Post subject: |
Damn....thats what I thought too. They look alot like rabbit rods.....or some of the other WC vw products. The squarish big end ...... Ray |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Tue Nov 18, 2014 2:02 am Post subject: |
Iis that one of those "drop in " strokers from way-back-when? What's the clearancing inside the case like? |
56vwoval Samba Member
Joined: March 21, 2010 Posts: 186 Location: nowhere USA
Posted: Tue Nov 18, 2014 5:02 am Post subject: Rods |
Gene Berg made a Rabbit rod crank years ago and discontinued it for problems! _________________ Remember guys and girls, you can be right or you can be happy with your significant other! You decide which is right at that time! |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Tue Nov 18, 2014 9:40 am Post subject: |
What does the case center main look like? |
mark tucker Samba Member
Posted: Tue Nov 18, 2014 4:54 pm Post subject: |
bearings sure look nasty. |
Art.b Samba Member
Posted: Wed Nov 19, 2014 6:59 pm Post subject: |
Got the case split, found center main bearing pretty worn out as well as the rod bearings in rough shape. The case bearing saddles look awesome not pounded out and std std!! I was hoping it would at least be a 82 stroke with stock rods so All I would have to buy are rods but looks like I'll be shopping for a crank and rods. a few more questions, would rabbit rods have 3/8 on them? or are these copies of rabbit rods? and what's should I expect the value of a 82 stroke rabbit roded crank to sell for?? Thanks for all the input!
_________________ THE MOTOR CITY |
modok Samba Member
Posted: Wed Nov 19, 2014 7:37 pm Post subject: |
Must be aftermarket rods but early 1.6/1.8 watercooled rod is same 136mm "porsche" length.
Not worth much, I mean, it's cool but there is a reason nobody is doing this anymore |
Art.b Samba Member
Posted: Wed Nov 19, 2014 7:54 pm Post subject: |
p/n:71-3084 also has std, 9-85 _________________ THE MOTOR CITY |
modok Samba Member
Posted: Wed Nov 19, 2014 8:01 pm Post subject: |
yep, that is a glyco bearing, but it does interchange with the clevite and ACL numbers above.. Whatever it is............the bearing thinks it's a rabbit |
Art.b Samba Member
Posted: Wed Nov 19, 2014 8:11 pm Post subject: |
I did a quick search and it also comes up 5 cyl Passat. look like beefy rods to bad they are so small on the rod journal. thanks for your help!! _________________ THE MOTOR CITY |
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
That is a rabbit rod crank set-up....
Those were marketed by CB Performance for awhile. There might have been some other companies selling them also.
I do not think Gene Berg ever offered this. He was in favor of a thick narrow rod journal, like the Porsche design.
They were never very popular because they flexed and broke due to the small cross section of the rod journal.
I wouldn't sell it to anyone. |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Wed Nov 19, 2014 8:13 pm Post subject: |
Joe- The Bergs played with them for a while and then dropped the combo from their catalog. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Type 5 Joe Banned
Posted: Wed Nov 19, 2014 8:15 pm Post subject: |
Wow, I would be surprised.... I'll have to look through me archives.
I have literature spanning almost 30 years from the Bergs. |
Posted: Thu Nov 20, 2014 5:24 am Post subject: Rods |
Look at Bergs 1990 Catalog. _________________ Remember guys and girls, you can be right or you can be happy with your significant other! You decide which is right at that time! |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Thu Nov 20, 2014 5:55 am Post subject: |
Looks like normal ware, how many miles on it?
rods look good to reuse? why not just find new bearings? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Art.b Samba Member
Posted: Thu Nov 20, 2014 6:30 am Post subject: |
I think it would be use able for a mild . I'm looking set my Rev limiter on kill. Fortunately the case and heads are in great shape. I think I would pass this along to some one that could use it. _________________ THE MOTOR CITY |
Posted: Thu Nov 20, 2014 12:07 pm Post subject: |
If the crank is cracked it would not surprize me. Dan |
