AlanInMass54 Samba Member
Joined: August 29, 2003 Posts: 1065 Location: Massachusetts
Posted: Wed Nov 26, 2014 9:13 am Post subject: |
Yeah keep the green one for sure! Lots of cool stuff, looks in decent shape too! Ignore the vultures wanting parts off it that are probably flooding your private message box. |
Gwdghiaguy Samba Member
Joined: December 06, 2013 Posts: 340 Location: Greenwood, SC
Posted: Wed Nov 26, 2014 10:00 am Post subject: |
AlanInMass54 wrote: |
How did you know? As I spend more time looking at her, I'm coming to appreciate Cinderella more and more. I haven't developed the discerning eye you old hands have. I appreciate your informed opinions on what to do with her.
byron _________________ 1957 Oval Window
1963 Alabama Camper Bus
1971 Ghia
1971 Baywindow Bus
D-train Samba Member
Posted: Wed Nov 26, 2014 12:12 pm Post subject: |
cinderealla is more like an ugly duckling, waiting to be a beautiful swan...
it looks solid from the pics, a heavy foot and a big hammer will massage those bent panels back straight..
just like this..
but even still, the barn find (what the thread is about) is amazing too. factory black an complete. such a good looking solid car by the pics too. some new fuel, oil change and away it should go!! _________________ shiny paint doesnt make it worth any more |
Rome Samba Member
Joined: June 02, 2004 Posts: 9603 Location: Pearl River, NY
Posted: Wed Nov 26, 2014 3:56 pm Post subject: |
Cinderella? Suitable, sure. But since Byron will be the prince to revive her, and she's jungle green, how about renaming her to "frog prince"? Remember that she crouched in the grass for ages as well.
That technique will certainly also work for the large, shallow dent on the driver's door- Just wear sneakers or work boots, position your right foot on the door, and press. You;ll have to first remove the window winder mechanism so you can reach your toe up as high as possible. Keep increasing the pressure until you hear the metal pop and feel your foot move outwards. Reposition your foot to another dented area on the door and repeat. The hood will take some more work because the dents go into the creased sections which are inherently stiffer than the flat door skin. Saving original metal with such crude techniques is fulfilling and instantly gratifying!
As to Frog's dash gauges, if they were fitted in Germany (likely), remember that dealer and general shop technicians there were taught to do things correctly as part of their trade training/apprenticeship. So the gauge positions were measured carefully, the holes cut, deburred, edges touched up, etc. Though looking at all those blue wires on the gauges go against a systematic hook-up... |
Posted: Wed Nov 26, 2014 5:36 pm Post subject: |
D-train wrote: |
but even still, the barn find (what the thread is about) is amazing too. factory black an complete. such a good looking solid car by the pics too. some new fuel, oil change and away it should go!! |
I took the carb off the barn find 57 to look for nasty congealed gas and crap on the inside but it was clean as a whistle!
And what about this brass fitting soldered just under where the carb attaches? Is that stock? What's that for?
I'll order a carb rebuild kit to get new gaskets and put it back on. And I'll go ahead and do new plugs, points, condenser, etc before trying to fire it up. 35 year old plugs don't fill me with optimism.
Wanted to take the dizzy out to give it a good cleaning but it wouldn't lift out. Turns freely but wouldn't lift up. Does it have to be in a certain position to come out? I did this once on the Ghia but I don't remember it being an issue.
Got the choke cable freed up; it moves nice and easy now as well as the accelerator cable. It seems like this car wants to get back on the road!
Guess I need to take a look at the fuel lines next. I know the tank is cruddy inside. can see and smell bad things. I'll do a search before I ask you all about how to take out the tank and dealing with the fuel cut-off valve, etc.
Happy Thanksgiving.
Byron _________________ 1957 Oval Window
1971 Ghia
1971 Baywindow Bus
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Wed Nov 26, 2014 6:20 pm Post subject: |
Not sure if the picture of the distributor was before or after you tried, but in the picture the nut is still there that fastens the dizzy/clamp to the engine case |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1318 Location: Bella Coma Canada
Posted: Wed Nov 26, 2014 6:45 pm Post subject: |
not stock
it is for the vacuum gauge _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS |
Posted: Wed Nov 26, 2014 7:38 pm Post subject: |
txoval wrote: |
that was before. It just needed a little persuasion.
Da TOW'D wrote: |
not stock
it is for the vacuum gauge |
thanks. maybe the po had one on here at one point. Cinderella is the one with the vacuum gauge. This motor is in the black 57. _________________ 1957 Oval Window
1971 Ghia
1971 Baywindow Bus
Abscate Samba Member
Joined: October 05, 2014 Posts: 22568 Location: NYC/Upstate/ROW
Posted: Thu Nov 27, 2014 1:42 am Post subject: |
Vacuum gauge is the only thing that makes sense. Engines might have been swapped at some point??
You can stop those PMs with a " not parting out" post
_________________ .ssS! |
Posted: Thu Nov 27, 2014 8:48 am Post subject: |
I'm a big fan of using a vacuum gauge , so I think the PO was right on the ball.
I have vacuum gauges on most of our gas powered engines.
cheers on a great bunch of scores
hank _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
and NUTS |
Posted: Fri Nov 28, 2014 6:49 pm Post subject: |
Cleaning up the distributor on the barn find 57; should the arm (arrow) on the vacuum advance unit move in and out slightly? mine does not move at all. If mine is not right, can I refurbish it? I've searched but haven't found too much info on this item. Thanks!
1971 Ghia
1971 Baywindow Bus
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Fri Nov 28, 2014 8:01 pm Post subject: |
Byron,
You can hook up a vacuum pump to the threaded port, the arm should move with vacuum pressure. Most times though, if it doesn't move the diaphragm is cracked or to dried out. You can swap the vacuum canister from another distributor though. It will still run with a bad vacuum canister, but won't advance like it should.
Scott |
Posted: Sun Nov 30, 2014 7:02 pm Post subject: |
Been trying to sort through the parts stash. It's a pretty big job, not that I'm complaining. Found an old can that was rusted shut; finally got it open and found this.
SCORE! Just like Christmas here last night when I got it opened and saw that.
Here is an update: got the tank out and am soaking it with water and vinegar. You would not believe what came out of that thing. Just disgusting.
Got the master cylinder out--planning to replace everything associated with brakes. Waiting on my carb rebuild kit and points and condenser. Tore the distributor apart and gave it a good cleaning. The engine cleaned up pretty good too. And am cleaning years of gunk from underneath the car. Engine cleaner and my power washer do a pretty good job.
I'll keep you all updated if and when anything interesting happens.
1971 Ghia
1971 Baywindow Bus
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1274 Location: australia
Posted: Tue Dec 02, 2014 3:42 pm Post subject: |
hi Byron, I guess you're having heaps of fun playing with your new toys, but can we hassle you for some more pics of the 2nd black car and the inside of the red one??? please.
we need our pipe dream fodder.
most of us are overjoyed to get one vw key with it's ignition switch... you scored there. |
steveo_32 Samba Member
Posted: Tue Dec 02, 2014 4:49 pm Post subject: ....wow |
So awesome, Enjoy ever bolt you take off!! green and black should be saved for sure, red is tooooooo far gone! )my 2 cents) |
Posted: Tue Dec 02, 2014 8:00 pm Post subject: |
thanks for your comments. Henry, I will get red and black pics tomorrow and try to get those posted tomorrow night. Almost too ashamed to show how bad they are. Red has almost no floor and black has no engine and not much interior left. These two were the ones left in the woods since forever. But I will let everyone see what's there.
And Steveo you are right about red. I probably will get a few parts off her to sell. See you all tomorrow night.
1971 Ghia
1971 Baywindow Bus
Posted: Wed Dec 03, 2014 7:19 pm Post subject: |
And here are some of the black '57 with no motor. Again, no cleaning done at all. Been spending all my time on the barn find, of course.
beauty rings all the way around:
1971 Ghia
1971 Baywindow Bus
Posted: Wed Dec 03, 2014 7:26 pm Post subject: |
Byron...you have SO much $$$ in parts there! The interior of the black car needs to find it's way into my 56' rag! The Lemmerz beauty rings are some serious coin..but you have got to put them on your black barn find car or the green one with all of it's accessories it already has.
Don't think the red car is too far gone, you should see the work our friends across the pond are doing with rusted cars like yours. It's awe-inspiring!!! |
Posted: Wed Dec 03, 2014 7:32 pm Post subject: |
motofly196 wrote: |
I've been day dreaming about what those rings, extra visors, etc. might look like on the barn find. And the horn button from the black 57 is mint. It will definitely go on the barn find. I guess I should get covers for all of them, huh? _________________ 1957 Oval Window
1971 Ghia
1971 Baywindow Bus
