123386 Samba Member
Posted: Wed Nov 19, 2014 3:20 pm Post subject: DOH! Drove for awhile with the hand brake engaged |
So I realized earlier today that I drove for awhile with my hand brake engaged, including some freeway driving. It wasn't fully cranked up, but it was almost fully engaged. Could I have done any serious damage to my brake system or engine?
Also, is it better to leave the car parked in gear? Or out of gear with the hand brake engaged? Or both? |
-Zodiac- Samba Member
Joined: September 22, 2014 Posts: 782 Location: Pensacola/milton, florida
Posted: Wed Nov 19, 2014 3:35 pm Post subject: |
I've done this before, when I first got mine. They could have gotten so hot to warp the drums. I don't think mine warped.
I use my hand brake without the transmission engaged. You can use the transmission, I probably would if I was on a hill. _________________ 1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed Nov 19, 2014 4:20 pm Post subject: 1st |
I have done that several times, in the past. I'd bet you're okay.
I am now in the habit of never using the hand brake on any of my cars, including my modern Hondas and Toyotas, for the very same reason as you stated. I only put the cars in first gear to hold them in place, when parked.
Have been doing this for 30 years...some others will disagree with the method, but i'll continue anyway...a good habit to get into, in my opinion _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
c21darrel Samba Member
calexican Samba Member
Joined: June 11, 2008 Posts: 730 Location: El Paso, TX
Posted: Wed Nov 19, 2014 5:36 pm Post subject: |
In my 1960 beetle handbook it said to put the car in gear when you park, but someone, and I'm thinking it was the dealer, marked it out in pen and wrote on the side, Don't do this! In large letters and underlined twice. So I don't do it, I got into the habit of using the e-brake, in my mind I'm thinking it's not putting any undue pressure on the trans. I've done what you did too, and I drove around a few months with the valves adjusted completely wrong, these cars can take a lot of abuse, even when we don't realize it. |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Wed Nov 19, 2014 5:52 pm Post subject: |
My (late) stepfather said that you should park your car in your garage in neutral and with the handbrake off so that, in case of a fire, you can pull it out of the fire by the bumpers.
If you have a problem with that, he said, put an old shoe you can kick out of the way behind a wheel. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Wed Nov 19, 2014 8:13 pm Post subject: |
If you don't use your E brake it often seizes up. It was meant to be used. _________________ 1958 Karmann Ghia owner |
akear Samba Member
Joined: August 18, 2013 Posts: 359 Location: Los Angeles
Posted: Wed Nov 19, 2014 8:19 pm Post subject: |
My father (also late) always said neutral when parked on street. You don't want your transmission ruined too if you are hit when parked. (But I always leave in gear + handbrake wherever I park.) |
123386 Samba Member
Posted: Wed Nov 19, 2014 8:37 pm Post subject: |
U guys rock. Thank you for your opinions.
Once I realized it was still engaged, I did smell a bit of a brake overheating, but not very intense and it was short lived.
I am still kinda newbie, so that's why I was worried about my engine. it's a solid rebuilt 1600cc and it was making a different sound after i released the brake. i may have just been hearing things, since it has been a VERY long day. I will know more during tomorrow's drive.
From what I have researched, the engine should not have been damaged by this oversight, and I seriously doubt the rear drums got warped. But I will do my due diligence this week and investigate as I need to make a front brake adjustment anyways. I love my Bentley book (love u blue!!)
kiwighia68, if I had the ability to like your comment I would, as I too had a step father with the similar snarky. Cheers to you. I hope to visit your great country someday soon!
Thanks guys for putting a newbie at ease. Be well. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Thu Nov 20, 2014 3:40 am Post subject: |
You won't hurt the engine driving with the parking ( e, emergency, hand) brake on.
Usually what goes wrong first is the heat kills the seals in the wheel cylinders and you get a massive hydraulic failure. Pay attention to both both your fluid level in the reservoir and smell your rear wheels after each drive for a few weeks to check for this. _________________ .ssS! |
123386 Samba Member
Posted: Thu Nov 20, 2014 1:15 pm Post subject: |
I just looked at the reservoir and it is completely empty, bone dry. Last time I looked at it, about a month ago, it had sufficient fluid inside (if I remember correctly, lots going on in my head these days). If the seals in the wheel cylinders blew, shouldn't I be seeing brake fluid stains and possibly fluid on the inside of the rear tires and on the garage floor? I didn't drive it at all yesterday after that drive with the parking brake engaged.
Posted: Thu Nov 20, 2014 1:38 pm Post subject: |
Yeah look for brake fluid seeping out onto the wheels, look for it by the brake pedal and by the master cylinder.
It should just disappear
So put some in it and see where it goes. _________________ 1973 karmann ghia - current, not the last VW.
123386 Samba Member
Posted: Fri Nov 21, 2014 12:49 pm Post subject: |
So far from what I can see, the leak is at the master cylinder, considering the amount of caked fluid I see around there, and the stains underneath on the pan. But none of it was really fresh to touch. And as I stated before, I never saw any puddles on the garage floor.
I had a friend over late last night and I put some fluid in the reservoir and had her pump the brakes, but i never saw any fluid squirting out of that line. Maybe there is still a bunch of air in the line? I would think it would get to the MC fairly quickly.
The line at the MC, from the reservoir, has alot of play in it. I see the seal is raised, there is a gap. Should the line be that loose? And that seal popped up like that? The Bentley doesn't really give specifics...
Any thoughts guys? |
123386 Samba Member
Posted: Fri Nov 21, 2014 2:14 pm Post subject: |
Thanks. As far as cleaning brake fluid, soap and hot water? Simple green? Any thoughts?
So do you agree the leak is at the line to the MC? Should the line fit very snug in the MC or have some play? Why no fluid coming out when the resevior was filled and the brakes pumped last night?
Thanks again man. |
Posted: Fri Nov 21, 2014 2:50 pm Post subject: |
Quote: |
So do you agree the leak is at the line to the MC? |
I think I said
Quote: |
That fluid doesnt just disappear. You really need to go thru the whole brake system front to back. Stopping is kinda important. |
You for sure at some time had a ugly leak at the M/C.
Soap/water/simple green, a stiff brush...get rid of all of it til its clean and dry. Sand it, Re-paint it.
The rubber plug has to be snug.
Inspect your slave cylinders, (at each wheel) take off the drums if necc. Clean away the dust/dirt and clean with your soappy simple green solution and dry them. Fill the reservoir and re bleed each wheel while watching your fresh clean slave cyls. for any leaks. Follow the hard lines and soft lines especially at the connections, inspect them for leaks. Dont forget the line that runs under the pedal assembly to rear brakes.
Dont forget to check on the back brake shoe that the ebrake rides on. _________________ GhiaBuild
1967 DC build
123386 Samba Member
Posted: Wed Dec 03, 2014 11:45 pm Post subject: |
The new M/C is in and there are no leaks there at the new seal or switch. But I am curious what all of you are running on the line from from reservoir to the M/C? My 4 inches of hose is leaking slightly...
Should I clamp at the plastic tip coming from the reservoir? |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Thu Dec 04, 2014 3:14 am Post subject: |
Crooked wrote: |
http://www2.cip1.com/ProductDetails.asp?ProductCode=VHD-N20-3501
_________________ 67 bug x3
67 ghia
64 bug |
RHough Samba Member
Posted: Thu Dec 04, 2014 6:33 am Post subject: Re: DOH! Drove for awhile with the hand brake engaged |
Crooked wrote: |
When the hand brake is on the engine stalls before the car moves. If you can drive your car with the hand brake on there is something wrong with the car or you need to eat more Wheaties.
The correct way to set a hand brake is to step on the brake pedal to apply the brakes. While holding the brake pedal down pull the hand brake lever up to hold the brakes in the applied position.
If the brake will not hold well enough to stall the engine, take the brakes apart and repair them. The design is the hand brake serves for both parking and as the emergency braking system in case of hydraulic failure. It should be easy to lock the rear wheel using the hand brake.
Things to check:
Brake adjustment
Correct brake shoe contact with drum
Correct brake return springs installed correctly
Parking brake lever and link installed correctly
Brake shoe hold down springs installed correctly
Brake backing plate contact areas where shoe sit are clean, smooth, and lubricated.
Brake cable working smoothly and installed correctly
