advinnie Samba Member
Joined: November 18, 2011 Posts: 1389 Location: oxfordshire
Posted: Thu Nov 20, 2014 4:46 am Post subject: stock 20mm oil pump on a full flowed engine |
Hi all just a quick one here. I have just built myself a 2054cc beetle engine (74mm crank with 94mm pistons ) and it has a full flow oil system so I can use a external filter anyway I was planning on using my stock oil pump witch has 20mm gears but have heard that this pump will not be up to the job is this true if so what size pump do I need 26mm, 30mm or larger?
Cheers |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Thu Nov 20, 2014 4:51 am Post subject: |
What case?
Late model dual relief cases used a 26mm pump. _________________ Glenn
Member #1009
#BlueSquare |
Randy in Maine Samba Member
Usually they use a 26mm oil pump. |
Posted: Thu Nov 20, 2014 4:57 am Post subject: |
The case is a super race case with dual pressure relief. My pump gears are 21mm not 20mm sorry about that. |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Thu Nov 20, 2014 5:08 am Post subject: |
By the time the oil gets past the filter you are probably going to end up with a lack of pressure at the bearings - use a 26mm pump. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Thu Nov 20, 2014 5:14 am Post subject: |
Ok then a new 26mm pump it is I take it that a 30mm pump is just to big I only ask cause I've just found someone selling one. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Thu Nov 20, 2014 5:58 am Post subject: |
30mm can be used if you have a deep sump? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Glenn Mr. 010
Posted: Thu Nov 20, 2014 6:28 am Post subject: |
madmike wrote: |
30mm can be used if you have a deep sump? |
Deep sump has nothing to do with the pump. A 30mm with new bearings will cause excessive oil pressure and cause the pressure relief valve to be opened and dumping oil.
More is not always better. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Nov 20, 2014 6:57 am Post subject: |
Right I will definitely get a 26mm gear pump. Just curious what size are stock 1600cc engine oil pump |
Glenn Mr. 010
Posted: Thu Nov 20, 2014 6:59 am Post subject: |
advinnie wrote: |
26mm was the stock size for a 1600. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Nov 20, 2014 7:04 am Post subject: |
Ok now if the 26mm gears are for a stick 1600 motor are you sure they will give enough flow now a external filter has been fitted? |
Glenn Mr. 010
Posted: Thu Nov 20, 2014 7:06 am Post subject: |
advinnie wrote: |
Yes... I have a 26mm pump in this.....(2180, FK8, 9.5cr)
50psi oil pressure @ 3000rpm with 10W-30 oil.
Member #1009
#BlueSquare |
Posted: Thu Nov 20, 2014 7:25 am Post subject: |
Cheers mate 26mm it is thanks for the help all |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Thu Nov 20, 2014 7:26 am Post subject: |
Glenn wrote: |
advinnie wrote: |
Glenn, Correct me if im wrong, But wouldn't that pressure @ that rpm cause the oil cooler to be bypassed?
I assume that's HOT pressure (your temp gauge), since cold oil @ that RPM would be 60+ psi
The bypass is active when the oil is over 40-45 psi?
Let me know _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Glenn Mr. 010
Posted: Thu Nov 20, 2014 7:35 am Post subject: |
I think the bypass is more like 80psi. _________________ Glenn
Member #1009
#BlueSquare |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Thu Nov 20, 2014 7:44 am Post subject: |
21s work well with full flow systems, but go with a 26mm for insurance. They make up in volume for a lack of blueprinting. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
kadub Samba Member
Joined: November 04, 2004 Posts: 444 Location: Auburn, Wa
Posted: Thu Nov 20, 2014 8:27 am Post subject: |
I run a 21mm pump in my turbo 2110 engine with"perfect" pressure for the stock oil control/cooler system. You DON'T want or need 50psi above 3,000 rpms once everything is up to temp. I run a full flow filter, grooved lifters and a journal bearing turbo. 21mm pump does the job very well with mobil 1 0w-40 oil in fact. 26mm won't "hurt" anything, but it would benefit you to do some research on the stock oil control system . _________________ Karl
aka Turbobaja |
Posted: Thu Nov 20, 2014 1:55 pm Post subject: |
I fully understand how a stock oil system works ive had no trouble at all with the 21mm pump in my 1699cc engine but with the extra oil lines (1/2" diameter) and the restriction the oil filter will give wouldn't the 21mm pump lack the flow/ pressure to work the vw oil system correctly? |
bluebus86 Banned
Posted: Thu Nov 20, 2014 2:24 pm Post subject: |
advinnie wrote: |
the larger pump will give you more margin with your added restrictions. for folks worried about the excess pressure causing the cooler to be bypassed, the solution is a remote cooler with a thermostatic rather than pressure based bypass valve. That is what I use in my van. I prefer the larger pumps when I route a cooler and filter. On one car I have over 25 feet of oil hose/piping.
when the engine is old and tired, the extra margin a larger pump gives may help out more than when the engine is new. if you only had 30 psi at 3000 rpm when the motor is new, what will it be when things are well worn?
Of course there is no free lunch, a larger pump pushing pressures that is bypassed is wasting power that could be used to turn the tires. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Thu Nov 20, 2014 2:28 pm Post subject: |
The flow requirement is the same, almost no matter how much oil piping you have. A restrictive filter may have to be overcome with more pressure, but that would be a bad filter anyway. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
