weldvair Samba Member
Joined: January 17, 2009 Posts: 98 Location: CENTRAL FLORIDA
Posted: Thu Nov 20, 2014 7:38 am Post subject: front tires |
The front tires on my KG leak air around the rim with the low (18PSI)
tire pressure.
The wheels are the old empi 8 spoke alum.
What is the cure?
Don |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Thu Nov 20, 2014 7:40 am Post subject: |
Have you considered using inner tubes? |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Thu Nov 20, 2014 8:04 am Post subject: |
Sand out corrosion inside of rim till even and smooth. Spray clear coat on inner rim to help prevent further corrosion. Use bead sealer on the tire when remounting. |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
kingkarmann Samba Member
Posted: Thu Nov 20, 2014 11:01 am Post subject: |
KGCoupe wrote: |
I second this solution. Install, rebalance, run and done _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Posted: Thu Nov 20, 2014 11:30 am Post subject: |
kingkarmann wrote: |
KGCoupe wrote: |
I second this solution. Install, rebalance, run and done |
This solution is fine, but will end up costing $90 to $150 for some place to remove the tires to put the inter tube in. Even if they don't fully remove the tire, dollars for donuts they'll hit you up for wheel balancing. My suggestion of the green slime is something you can do yourself and is a $10 to $20 dollar fix, and it does work well. |
scottz Samba Member
Joined: April 13, 2008 Posts: 477 Location: Bellingham, WA
Posted: Thu Nov 20, 2014 8:11 pm Post subject: |
kman wrote: |
This solution seems the best to me.
Are you sure they are leaking at the bead? Aren't old Empi 8 spokes two piece wheels? If so, cant the seal go bad between the two halfs? Green Slime seems like a lazy solution, but it may be best if the old wheels are in question. |
Posted: Fri Nov 21, 2014 6:40 pm Post subject: |
Thanks for the help.....Don |
