Sherrinonie Samba Member
Joined: October 22, 2011 Posts: 133 Location: Santa Monica
Posted: Thu Nov 20, 2014 9:43 am Post subject: Front End Suspension |
Had new ball joints and bushings done. Now there is gyration/trembling of the steering when braking and going 60 or higher. Back in shop now. Suddenly happened after work was done. What could this be? Thanks!! |
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Thu Nov 20, 2014 9:59 am Post subject: Re: Front End Suspension |
Hopefully just a bad alignment. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Thu Nov 20, 2014 10:23 am Post subject: |
Just found out its a severely warped rotor. How can this suddenly come about after new ball joints and bushings?? |
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Thu Nov 20, 2014 10:31 am Post subject: |
Maybe they didn't torque the wheel? Or jacked the van up on the rotor end? I have found most radius rod bushings are pretty worn out and that may have upset the alignment when they pulled them off? _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
danfromsyr Samba Member
Posted: Thu Nov 20, 2014 10:35 am Post subject: |
best case scenario, bad luck
worse case scenario they swapped your rotor for someone elses..
but possibly (*Idunno) reinstalling the rotor (*Idunno if/why) they have it adjusted too loose.
it's a PAIN when you are at the mercy of a repair facility
it's also a PAIN when you are your own mechanic and still have these unknown issues
(but they cost less)
less if you don't mind the time+aggravation+busted knuckles+sore back/knees+dirty hair + grease under your finger nails+time spent away from family/loved ones _________________
Abscate wrote: |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Thu Nov 20, 2014 10:52 am Post subject: |
I bet it's actually your tyre pressure, alignment or both. It us possible to damage a rotor by torquing though.
Neil2 |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Mon Nov 24, 2014 10:43 am Post subject: |
I just had the same problem. Suddenly had steering wheel vibration when traveling over 65mph. Couldn't figure out what was going on. Took it to a good VW mechanic who couldn't find anything wrong but said that he noticed a very slight brake pedal pulse when first applying the brakes and said that was likely due to a slightly warped rotor. Replaced the front rotors and the vibration is gone.
Whether this could be related to your other repair, I can't say. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
tjet Samba Member
Posted: Mon Nov 24, 2014 12:43 pm Post subject: |
What was the reason you took the van in the shop in the first place? It is possible that the work performed exposed a problem that was already there. It may have not been noticeable before. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon Nov 24, 2014 1:40 pm Post subject: |
If the suspension had a lot of slop, it is possible the vibration was not making it up to you at the steering wheel. Tighten up the front end and you will feel everything. _________________ ☮️ |
