kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Thu Nov 20, 2014 8:28 pm Post subject: Removing '69 ignition? |
Well I have a '69 singelcab. A PO removed the original ignition, and put an aftermarket starter on the dash. I'm now on my second one of these over 7 years. I would like to go back to the original ignition in the pod on the steering column.
So a couple years ago I got an ignition and pod for my bus, with no key.
I can see that I can get a used ignition cylinder for a relatively reasonable price, which may be cheaper than trying to get this old one re-keyed. Also this old one looks like it is pretty beat up. I'm trying to figure out how to remove the old one - I think you are supposed to take a thick wire, and bend it around and into a small hole-which releases a spring, and helps get the ignition out. I've tried this - and the ignition cylinder does not really want to come out. I'm wondering if I need to have a key in it to pull it out?
Alternatively - I could just drill it out right? I'm just not sure if that would destroy the whole thing. Is that a decent alternative? _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Thu Nov 20, 2014 8:37 pm Post subject: |
The '69 bus uses the "L" code key profile, and that year ignition switch (68-70 I think) can not be re-keyed. So if you're going to try a used German lock cylinder, you'll need the key too! The electrical part of the switch can be swapped in the car in about half an hour, but removing the locking mechanism takes more time. You found the article about the '70 switch replacement that mentioned the bent welding rod? Good, because that's where the instructions are
www.airschooled.com |
Tcash Samba Member
Joined: January 01, 2007 Posts: 16865 Location: sticksville, ct.
Posted: Thu Nov 20, 2014 9:38 pm Post subject: |
don't drill it. find a old key it doesn't need to be the correct one, you need it to pull the lock barrel out. they just don't pop out.
i have a early lock assy out. i will take a picture for you if i remember _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Thu Nov 20, 2014 9:54 pm Post subject: |
Might be time to lay off the booze bro _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51131 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Nov 21, 2014 5:07 am Post subject: |
Thanks for the tip - especially the info that I need a key in the ignition to pull the old one out. That was oen thing I was not sure about.
I think I have a key that will fit - I'll take a look around. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Fri Nov 21, 2014 6:36 am Post subject: |
aeromech wrote: |
Might be time to lay off the booze bro |
how'd you know?
lets see, today i took the day off "work" to:
finish up a couple customer cars at home
run to the paint store for some supplies
make sure the killing plant is up and running as good as it can be
sign some hunting permits
move the first batch of 400 turkeys to the holding pit to get ready for tomorrow
secure 3 tons of ice
so i may forget _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Nov 21, 2014 7:03 am Post subject: |
Sounds like you live in Terminus _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Fri Nov 21, 2014 11:02 am Post subject: |
While you guys are dancing around like BD said let a pro do it or in my case show it . You don't need a key if the steel plate is still on the bottom of the pod remove the 4 screws you can now see the lock setup you will see what looks like a rivit head its just a plug (if its still threre) now take a piece of stiff wire bend into a L (rounding the end of the wire will make it work easier) push it in the hole wiggle the lock as you are pushing the wire in now take a thin bladed screw driver just under the edge of the key switch and pop it out. if it doesn't come out try again you may not have the wire set good.
This info only works on this style of switch 68-69 if it later or looks different this will not work. _________________ where its cold and snowy |
Posted: Fri Nov 21, 2014 7:46 pm Post subject: |
I GOT IT! Thanks. I was trying to release a spring on the top side, instead of through that visible hole. Thanks.
I forgot to add - that little rivet was missing on mine. Not sure if that means anything.
I've now got the key code-and can order up some keys.
Thanks again. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Sat Nov 29, 2014 12:47 pm Post subject: Turn Signal Ring |
OK, so now I'm trying to put a new dash pod onto my bus. When removing the steering wheel, I bent the turn signal cancel ring. Piece that look something like this - http://www.socalautoparts.com/product_info.php/aftermarket-turn-signal-canceling-ring-bug-p-16579
I have bent it back, but if I could get a new one, I would. Anyone know what this part number is, and if it is possible to get a new one - and am I calling it the right thing?
thanks. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Sat Nov 29, 2014 1:37 pm Post subject: Re: Turn Signal Ring |
It is the canceling ring. There are debates to which way it goes- it will work (but differently) both ways, right and left of the column. Stock is left. My aftermarket one didn't work so I had to bend it into place. You should just bend yours until it gets close, then bump the signal pod up until it works with about 2mm clearance to the wheel. Not working? Rebend the tab.
Robbie
EDIT: Factory clearance is 2mm, but my aftermarket wheel + aftermarket switch do not work together unless I shrink the clearance to 1mm. Thanks for the reminder Tcash. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
Tcash Samba Member
Posted: Sat Nov 29, 2014 5:56 pm Post subject: Turn signal switch to steering wheel clearance |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Sat Nov 29, 2014 6:44 pm Post subject: |
turn signal repairs with replacement switch
A bit of soldering, electrical tape and a few zip ties. The repair/hack has lasted twenty+ years, but it doesn't cancel by itself.
Aloha
tp |
Posted: Mon Dec 01, 2014 9:59 am Post subject: |
Well I got it all back together - and I stupidly forgot to mark the steering wheel - so it is not centered.
But a bigger issue - when I go to start the singlecab- the ignition does not spring back. In other words, I turn the key - and the key would stay in the "start" position. I imagine there is a spring missing somewhere - but I'm not sure where that would be, and what would be the bad part.
Ie what should i be looking to get to fix it?
Do I just need this:
http://www.thesamba.com/vw/classifieds/detail.php?id=1680942
or this:
http://www.thesamba.com/vw/classifieds/detail.php?id=1684725
Just to help clarify - this is for my '69 Singlecab. Type L profile keys. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Tcash Samba Member
Posted: Mon Dec 01, 2014 2:01 pm Post subject: |
Sorry to be so stupid about this - the ignition switch is the part that the key fits into, right? ie the short little cylinder? _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Tcash Samba Member
Posted: Mon Dec 01, 2014 2:53 pm Post subject: |
kguarnotta wrote: |
Sorry to be so stupid about this - the ignition switch is the part that the key fits into, right? ie the short little cylinder? |
#43 is the ignition switch. If the lock cylinder #41 is hanging up it will not allow #43's spring to return the key from the crank position to the run position. Lube it and see what happens.
Thanks to jerseylooker
Posted: Thu Dec 04, 2014 5:44 pm Post subject: |
Thanks Tcash - diagram is very helpful. I never know what to call all the individual parts. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
