1969 Beetle Front Left Quarter
What to do?
Nothing, it's fine. Except maybe the right fender.
100%
 100%  [ 1 ]
Run away, sell it. It'll never be right!
0%
 0%  [ 0 ]
It's not right, but live with it...
0%
 0%  [ 0 ]
A good body man should be able to straighten this out in minutes without causing other problems
0%
 0%  [ 0 ]
Total Votes : 1
Heafust
Heafust is offline
PostPosted: Thu Nov 20, 2014 10:27 pm    Post subject: 1969 Beetle Front Left Quarter Reply with quote
Is this a crease(damage) or a style line? -About 1 1/2 in. out from fender-
It is so perfectly formed, it seems like it is supposed to be there. But the right side doesn't have the same look. Of course, the the fuel door being there may have something to do with it?
The next couple of pictures may or may not be related to my question. The left wheel sticks out from the fender further than the right side. The spacing between the tire and the fender is tighter on the left side than the right side. Somewhere, pre- me, the right fender was replaced. I have no idea how hard it was hit. I keep measuring it out and can't decide if that fender is different than the other, like off of a Super. ??.
theKbStockpiler
theKbStockpiler is offline
PostPosted: Fri Nov 21, 2014 6:41 am    Post subject: Reply with quote
First guess with paint on is that the quarters were patched. Edit: Can you see from the inside if there is a seam from a patch panel?
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Fri Nov 21, 2014 7:04 am    Post subject: Reply with quote
You need to post pictures of under the hood looking down at that front quarter panel, the apron area, etc.. If this beetle sustained a front hit that could of buckled that quarter, it should be very obvious under the hood or under the fender.
The Samba member since 2004.
marklee
marklee is offline
PostPosted: Fri Nov 21, 2014 10:57 am    Post subject: Reply with quote
looks like collision damage to me, the wing (fender) if hit has pushed into the 1/4 causing the crease, a common issue..
CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver
