sherrylhendershot Samba Member
Posted: Fri Nov 21, 2014 1:52 pm Post subject: 28pci carburetor plug |
Does anyone know where I can find the plug or fitting to plug the hole on a German 28pci carburetor? My 1960 VW does not have a vacuum advance, therefore this hole needs to be plugged.
Note, this looks like a pipe threaded fitting, and does not have a post coming out of the carb.
Thank you. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Nov 21, 2014 1:55 pm Post subject: |
Need a pic as the only known threaded hols are for jets or bowl drains.
So visit hardware store and take carb with you. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
anthracitedub Samba Member
Posted: Fri Nov 21, 2014 2:26 pm Post subject: |
I just checked one I had laying around.... The thread size is 6mm X 1.00. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Fri Nov 21, 2014 3:36 pm Post subject: |
anthracitedub wrote: |
Is it a tapered pipe thread? |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
EVfun Samba Member
Posted: Fri Nov 21, 2014 4:28 pm Post subject: |
The 36HP engine used a hard line with fittings like the brake lines. I would use a brake line cut off and with a rubber vacuum plug over the cut end. _________________
Wildthings wrote: |
Posted: Fri Nov 21, 2014 4:52 pm Post subject: |
KTPhil wrote: |
The piece that I removed from th carb was straight thread.
I ran a die over it and it fit perfect. I couldn't find my pitch gauges, but the die was right on. |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Fri Nov 21, 2014 7:40 pm Post subject: |
EVfun wrote: |
The 36HP engine used a hard line with fittings like the brake lines. I would use a brake line cut off and with a rubber vacuum plug over the cut end. |
Not the last versions of the 36 hp engine!
note; the 40hp fresh air exhaust and the special long 36hp heat riser tubes on the intake manifold! The Sea Blue car was built Jan 13, 1965 and the engine is a matching numbers to the car. The factory engine photo is a KD replacement engine for fresh air 36hp engines built from 1963 to August 1965
Also not that the 28PCI in those later years have a pressed in fuel inlet to the carburetor compared to the earlier screw in hard line fitting.
https://www.thesamba.com/vw/gallery/pix/516081.jpg
http://i132.photobucket.com/albums/q16/threespoke/standardkafer/literature/LIT265brocengine.jpg |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Nov 22, 2014 9:29 am Post subject: |
I found mine at the local (rural) hardware store, it was even brass like the one above. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
