Klammydia Samba Member
Posted: Fri Nov 21, 2014 9:29 pm Post subject: Oil sump stud replacement |
I post this in fear of being told to do a search. I have done much reading and have a pretty good idea of what I need to do. Being a novice I'm a little nervous and just want a little motivation before I start tomorrow. I did my first oil change on my own some months ago and when I went to do it again found the threads on one stud or possibly the nut are stripped. I think I've safely concluded it's not the one connected the the sump bracket inside. I've also come to the conclusion that the engine casing is not stripped there because I marked the stud and the nut spun but the marking therefore the stud didn't move positions. I think at this point I just need to use my bolt extractor back out the stud and loctite the new stud in place. I've also seen almost every post have some comment referencing using step-studs and less recommended Helicoils. So is it really as simple as I think it should be or am I in for a doozy. |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Sat Nov 22, 2014 3:32 am Post subject: |
Sweet, thanks for the reply Bret.
I drove to jbugs a few days ago to get the gaskets and picked up a stud while I was there. I just wanted to hear from someone else that this is going to be as easy as I thought.
Spencer |
Yabbadubbadoo Samba Member
Posted: Sat Nov 22, 2014 2:29 pm Post subject: |
Yeah! I got it out first try, and only sustained minor injuries! Off to get some loctite. Thanks for the tips and confidence that came with it. |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Sat Nov 22, 2014 5:05 pm Post subject: |
I Loctited two of mine in the summer, and two weeks ago I did another oil change and they came out again. I had to Heli-Coil them -- you can get them at Ace Hardware, if need be.
I hope yours don't come to that, though. _________________ 71 Elm Green FI A/T Squareback |
