User Samba Member
Joined: September 27, 2013 Posts: 170 Location: Marietta, GA
Posted: Fri Nov 21, 2014 10:05 pm Post subject: Deleted |
Delete Thread _________________ 1966 Beetle Pearl White
grandpa pete Samba Member
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Fri Nov 21, 2014 11:25 pm Post subject: |
The ragtop seems to be missing the rear hold-down . . . probably the easiest piece to find new. Look here . . . http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=115875553
D/P engine swap . . . pros . . . more power! Fresh air heater!
To make it a bolt-in, you can swap the flywheel to a 6volt-200mm.
Keep it 6volt generator if you want or use an internally-regulated alternator to convert the car to a 12 volt system. _________________ Jesucristo es mi Seņor y Salvador! |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1274 Location: australia
Posted: Fri Nov 21, 2014 11:33 pm Post subject: |
it looks like you are missing the short rails from the back corners
plus there should be (from memory, it's been a while) two canvas straps from between the front sliding section and the 2nd sliding section. they pull the second section forward when you close the roof.
the engine has a really late stale air fanshroud but to rear tin is for a later motor. you will need to block the holes or swap it out to one without holes, to stop hot air getting into the engine bay.
it looks like you don't have a breather on the oil filler thingy, but the aircleaner has a port (rhs near the top) for the breather tube. you will again want to swap bits of block off the hole.
it looks like you have a nice car there. enjoy, life is better with the roof back. |
cfelke Samba Member
Joined: October 05, 2007 Posts: 136 Location: Greenwood, Indiana
Posted: Sat Nov 22, 2014 12:06 am Post subject: |
If you want to have a little power, go with the dual port. You will need to grind out the transmission to fit the flywheel in but it will bolt up. |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1288 Location: South West (Pa.)
Posted: Sat Nov 22, 2014 3:14 am Post subject: |
That's a hell of a score you made there. I was watching that one too but don't have the room. It looks like your rear engine tin doesn't match the fan shroud. What type of heat exchangers are installed.fresh or stale air? It also needs an engine seal.I'd yank the engine 1st thing. Awesome score . |
User Samba Member
Posted: Sat Nov 22, 2014 6:39 am Post subject: |
thomas. wrote: |
The car is a later 1963. Didn't they convert to freshair mid year? Based on that if correct does it appear to be correct?
Thanks for all the help everyone. keep it coming. _________________ 1966 Beetle Pearl White |
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Sat Nov 22, 2014 8:32 am Post subject: |
some more pics of my bug's cousin! |
