pinksecond Samba Member
Joined: November 22, 2014 Posts: 2 Location: Jacksonville
Posted: Sat Nov 22, 2014 11:51 am Post subject: In and out movement on CV flange |
Installing a CV flange on transaxle and there is a small amount of in an out movement after I install the snap ring. DO I need to be concerned. |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Sat Nov 22, 2014 12:01 pm Post subject: |
That movement is necessary to allow for the difference in distance between the wheel and the transmission at the top or bottom of the suspension's travel. |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Sat Nov 22, 2014 5:35 pm Post subject: movement |
It sounds like you saying the inner race is moving on the shaft. Is the inside cone washer on backwards? |
Posted: Sun Nov 23, 2014 6:09 pm Post subject: |
Thanks for the help. What I am referring to is where the CV flange fastens to transaxle. put in new seals in trnsaxle and when I put on the CV flange and Circle clip on to fasten the flange to the transxle it has a little play in and out.
I think from reading its supposed to have a little play. |
Posted: Sun Nov 23, 2014 7:25 pm Post subject: |
If the motion is between the axle and the CV joint it is supposed to be there. If the flange on the drive stub to the wheel moves in and out you have a problem. Your brake drum is tightly mounted to the drive stub? |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sun Nov 23, 2014 10:20 pm Post subject: |
Looking at Fig. 6-10 in the Trans./Rear Axle chapter of the '70-'79 Type I Bentley manual, and the
relevant text, one gets the impression there is not supposed to be any axial play of the drive flange,
and in fact installation of the flange may require compressing the spacer ring underneath. _________________ '67 bug: seized by the authorities
