umphorever Samba Member
Posted: Sat Nov 22, 2014 4:51 pm Post subject: Scored a gas heater today |
Hey guys! I picked up a gas heater today. I haggled the guy and bought it for 80 bucks. It's a stewart warner model 8345c 12volt I can't seem to locate the exact manuals in the technical section. It appears on first inspection that I'm missing the cable. I'd love some technical advice if anyone is willing to help. I'll load up some pics here in a few. I've searched read through multiple threads trying to find the answers. Sorry if I'm beating a dead horse, but I'm cold!! |
Posted: Sat Nov 22, 2014 5:03 pm Post subject: |
[img]
Tag
[/img]
I assume that this is where the control cable connects to.
[img]
And I'm trying to figue out what this black thing is. It's been cut off. Looks to be insulated wire jacket?[/img] |
Aynthm Samba Member
Joined: July 07, 2010 Posts: 1315 Location: Beaverton, Oregon
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sun Nov 23, 2014 5:12 am Post subject: |
That black hose looks like a drain hose.On the ones I've had running I've never seen anything drain though. I'm guessing not that important. I'll try to post a link but I'm on my cell so not too swift in that respect. If it doesn't take you can search "The ultimate Stewart Warner gas heater thread".
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...gas+heater
Looks like it worked ! Forgot to mention you can buy a choke cable from any auto parts store and rig an on-off switch to your heater if you can't find an original cable switch. |
Posted: Sun Nov 23, 2014 11:23 pm Post subject: |
thomas. wrote: |
Thanks for the response. Good idea on the choke cable. I had a spare brake cable from my bicycle. I figured I could make that work. Right now I have had the whole thing broken down. I individually checked each motor and connections. Everything checked out individually. Then I reassembled the unit. I'm thinking I'm having issues with the fuel pump. I'm not getting fuel to the ignition point. I've got the little blue/white spark inside the chamber. Just no fire! I disconnected the fuel line to the burner, and it didn't show any evidence of fuel making it through to the burner. I'm taking my time and making sure I get this thing running properly. And safely. I had mentioned in the "ultimate stewart warner thread" that I'm thinking of installing a small lawnmower style fuel tank, just so the heater is just 1 piece unit. I'd also be leaving the stock fuel system alone. I welcome any ideas/suggestions on my progress. This week is supposed to get pretty cold and I gotta get warm!! |
Mexicant Samba Member
Joined: December 31, 2010 Posts: 99 Location: Colorado
Posted: Mon Nov 24, 2014 8:37 am Post subject: |
I couldn't get the fuel pump to work well enough on mine either, I figure the diaphragm was too worn or whatever. So I used an electic fuel pump 5-7psi and it works fine. Ran a relay for it triggered off the thermostat switch. |
Posted: Mon Nov 24, 2014 8:57 am Post subject: |
Where did you find the electric fuel pump? And what kind? I'd love to some pics of that setup! |
Posted: Mon Nov 24, 2014 11:55 am Post subject: |
It's an Airtex model e8012s fuel pump, mounted right at the front of the fuel tank and ties into a T fitting at the gas tank outlet below. The relay is just a standard spdt relay, Orange is power, green is grounded to the unit, blue is output to the fuel pump and the red is the trigger from the heater.
The other red wire with the black connector is what you'll need power to for the heater, whether its a toggle switch or you manage to find the proper cable setup for one.
Oh and ignore the red wire nut on the relay power, I still need to put another female connector and put it into the relay harness. It works so it hasn't been real high on the priorities.
Posted: Mon Nov 24, 2014 12:14 pm Post subject: |
Thanks! I'm seriously thinking I'm going to run a separate fuel tank for the heater...so basically I need to get a low pressure pump...between 4-10psi? |
Posted: Mon Nov 24, 2014 12:33 pm Post subject: |
I think the stock setup was about 7 psi if I remember correctly. Tied in with the relay the fuel pump only kicks in when he thermostat calls for it. Gas useage is pretty minimal and it'll have he car nice and toasty in under a minute. I don't have heater boxes at all in my baja so I'm still wanting to find a way to utilize the defrost vents. |
Posted: Mon Nov 24, 2014 2:24 pm Post subject: |
Mexicant wrote: |
I've been thinking about routing a vent for defrost. Where my hot air comes in the car is just a square hole. The po didn't have the vent for it...so what I plan on doing is fitting a piece of sheet metal over the hole with a 2" Round pipe coming out. Then attaching a y to it...Then attaching a piece of flex pipe to one side of the y and using a magnet with a round tool holder, sticking that to the dash with an attachment I got with a heat gun years ago. In using the magnet, you could easily remove the "defrost" hose, cap that side of the Y and stick it under the passenger seat, for whenever you need to use it. I'm not sure what you think of the idea, but I think it could work. I've got a 63, so I have no defrost as well. |
Posted: Mon Nov 24, 2014 4:22 pm Post subject: |
Sounds interesting definitely post up pics if you get that going. Last year I just used one of those 12v heater/defrost thingys from the auto parts store. It worked ok but not much volume of air across the windshield. |
Posted: Mon Nov 24, 2014 7:38 pm Post subject: |
for sure...those 12v plug ins are generally crap! Would you be willing to post up a pic of the cable assembly? where it connects to the thermostat? That's been puzzling me a bit. I got mine with no cable and that plastic piece that rides over the micro switch is confusing me a bit. Does the cable actually tie into that? I checked out the unit before I came into work tonight (I work 2nd shift) and noticed that I'm not getting spark in the combustion chamber now. My spark plug porcelain is cracked on the top side... |
Posted: Mon Nov 24, 2014 9:05 pm Post subject: |
Here ya go
Posted: Mon Nov 24, 2014 10:35 pm Post subject: |
thanks man!! I know this heater talk has been talked about so much that people are reluctant to talk to me about them. I really appreciate your help. I'm off work here in a half an hour. I'm going to check the fuel pump to decide whether or not I'm going electric. I will post updates! |
Posted: Mon Nov 24, 2014 11:05 pm Post subject: |
No problem, ask away! I know I spent tons of time pouring through pages and pages of threads just to find a certain pic of something, so maybe this thread will quickly answer someone else's questions in the future. |
Aynthm Samba Member
Posted: Tue Nov 25, 2014 12:47 am Post subject: |
Just curious about Beetle heating system. I have a '66 Beetle I restored with the factory heat exchangers still working and I get tons of HOT to very hot heat from behind the front seats or front floor or the 3 dash outlets depending on the adjustments of the 2 knobs on the tunnel. I couldn't imagine needing more heat even in ice cold Canada. Sometimes I need to crack the windows to let heat out.
What is it Im missing about needing a gasoline heater system? Is it really that cold that the factory system can't warm the interior up?
Thanks. |
Posted: Tue Nov 25, 2014 8:53 am Post subject: |
Aynthm wrote: |
Thanks. |
Well on my Baja part of my heater channels have been welded as a PO's repair so this was the easiest choice for me to have heat. Also there's no waiting to have heat as it'll toast you out of the car in a few minutes from the time you turn it on. |
Posted: Tue Nov 25, 2014 12:03 pm Post subject: |
Aynthm wrote: |
Thanks. |
For me, the po removed almost all of the factory heater system..my 2nd hand gas heater is way more economical than buying all new heater system components. Maybe before next winter I'll have everything. |
