J.R. Samba Member
Posted: Sat Nov 22, 2014 5:49 pm Post subject: Has anyone used the empi wiring kit on a trike ? |
started working on my trike and found that the p.o. had no idea about wiring was done with speaker wires and crap not 1 fuse used so pulled everything off. no wonder he never finished it . So was wondering has anyone used the empi wiring kit on a trike ? what does it have is it worth getting or should I try to pull the harness out of a junk bug ? or what are your suggestions ? this is my first trike build but not my first VW.
thanks
J.R. |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Mon Nov 24, 2014 11:00 am Post subject: |
Pulling out an old harness & going through it & splicing in the bike parts seems like work. Get a schematic & build your own harness. Simple fuse panel & some good wire ends & shrink tube & away you go. I am running a Ron Francis Bare Bonez kit & it is nice, labeled wires & nice clean fuse panel. _________________ I think he meant "rare", as in "not well-done" |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
V-driver Samba Member
Posted: Sat Nov 29, 2014 8:35 pm Post subject: Wiring your trike... |
J.R.,
I used this self contained wiring module/harness. It's from Ultima and is designed for custom chopper builds. I had to extend the harness length to the hand controls - I used H-D bagger controls. It works. Can be had, new, from Ebay sellers for about $150.
http://www.ultimaproducts.com/wiringsystemplus.html
Paul in Memphis |
