62ItalianRagtop Samba Member
Posted: Sun Nov 23, 2014 2:09 am Post subject: OG battery strap and optima battery |
Hi, can I use the original battery strap to fix an optima battery (red top) ?
Which is the correct battery strap for a 62 beetle ?
Thank you _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Sun Nov 23, 2014 3:07 pm Post subject: |
A previous owner of my car fashioned a plexiglass top with two aluminum channels to hold the Optima in place, and the battery hold-down strap goes right over it just as if it were an original battery.
_________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
djshutup Samba Member
Joined: April 16, 2013 Posts: 190 Location: United States
Posted: Sun Nov 23, 2014 4:38 pm Post subject: |
i installed a blue marine optima battery. I used the original metal bracket it grabs part of the optima to secure it. _________________ 1967 Volkswagen Bug (stock). 1980 Yamaha XS400 Special II (stock). Ya I like stock classics |
grandpa pete Samba Member
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Nov 23, 2014 7:58 pm Post subject: |
79SuperVert wrote: |
The 62 strap may be re-bent to fit over the Optima 6v redtop. I know I managed to stretch one over an Odyssey battery many moons ago- just needed reshaping and a plastic shim. _________________
EverettB wrote: |
FU#5 |
Posted: Sun Nov 23, 2014 10:07 pm Post subject: |
grandpa pete wrote: |
vwkind wrote: |
i installed a blue marine optima battery. I used the original metal bracket it grabs part of the optima to secure it. |
What type shutoff do you have on the kickboard ? |
battery cut off switch/key.
also the wood you see I use a piece of plywood over the battery with security screws so you can't easily bypass it. _________________ 1967 Volkswagen Bug (stock). 1980 Yamaha XS400 Special II (stock). Ya I like stock classics |
