Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Tue Nov 25, 2014 7:46 am Post subject: |
Yeah, it just depends on what kind of plane it was designed for. The Sonex kits use a case that has the nose machined to fit the prop hub, has a large hole machined in the bell housing side and also is clearanced like an automatic case. I have built longblocks for planes that would directly transfer to a car with no mods. Again, just depends on how it was designed. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Wed Nov 26, 2014 8:31 am Post subject: |
mark tucker wrote: |
yup somethen that looks like that on the inside would skeer the bejeebers out of me.no way it could possiably work in a car...so does any body know the reason for the high octane avgass???I know why but there seen to be some missconceptions. |
So what is so scary about that engine Mark?
Other than a cam change, it should be good as any other. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Wed Nov 26, 2014 1:17 pm Post subject: |
The high octane rating of Avgas is due to the fact the engine needs to take off at normal atmosperic pressure on the ground then run at a much lower atmospheric pressure at cruise. If the engine were built with enough compression to run properly at altitude it would detonate on takeoff with regular fuel. Traditionally, the high "octane" of avgas was obtained using large amounts of tetraethyl lead. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
mark tucker Samba Member
Posted: Wed Nov 26, 2014 1:31 pm Post subject: |
turboblue wrote: |
Other than a cam change, it should be good as any other. |
NOTHING. go figure. |
70turbobaja Samba Member
Posted: Wed Nov 26, 2014 10:20 pm Post subject: |
Some planes that have a vw engine also have a tapered crankshaft for the prop. Well my dads kit plane does atleast My.02 |
bluebus86 Banned
Posted: Thu Nov 27, 2014 10:44 am Post subject: |
Quokka42 wrote: |
The high octane rating of Avgas is due to the fact the engine needs to take off at normal atmosperic pressure on the ground then run at a much lower atmospheric pressure at cruise. If the engine were built with enough compression to run properly at altitude it would detonate on takeoff with regular fuel. Traditionally, the high "octane" of avgas was obtained using large amounts of tetraethyl lead. |
Airplane motors are Engineered differently than car motors. The Engineering requirements are different for an airplane verses a car. Engineers understand these things and design accordingly.
Aircraft can get away with lower octane fuel, in the correctly Engineered motor but to compensate for the thin air up there, they may have a forced induction system (Turbo, Super charger). These components are Engineered to work properly, as the life of the pilot and passengers depends on it.
Without well thought out Engineered systems, man would not be capable of flight. Engineering makes human flight not only possible, but also very safe. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
