honeyman Samba Member
Joined: November 23, 2014 Posts: 3 Location: Australia
Posted: Sun Nov 23, 2014 10:53 pm Post subject: Water under back seat |
i've been finding water under the passenger side back seat of my 73 super beetle after rain i believe it might be from the eyebrow vent behind the rear window. has anyone got any ideas on common leaks and possible ways to fix it?
thanks |
alex857 Samba Member
Joined: December 26, 2010 Posts: 714 Location: Stuttgart/Germany
Posted: Sun Nov 23, 2014 11:38 pm Post subject: |
Hi,
it is difficult to tell the source because the water moves around when the car is driving. Is the rest of the floor really absolutely dry?
However, the vents would be my last guess because either the death foam traps water or it drips on the inside of the side panels into the heater channels. Most probable are leaks of the sealing between the body and chassis, next guess are the window sealings (especially front and rear - is the trunk behind the rear seat really dry? (then the rear window is probably tight). Does the car have a sliding roof? Then check the draining.
Check if water collects only while driving in the rain but also just by sitting outside in the rain.
Good luck |
Posted: Mon Nov 24, 2014 1:01 am Post subject: |
the rest of the floor is dry when parked and there isn't any sign of it running from front to rear.
thank you mate i'd say you're probably right about the sealing between body and chassis. the trunk is dry and the roof is a hardtop.
she isnt driven to much at the moment so the water would be collecting when its parked.
thank you very much mate ill have to wait for it to rain again and start looking |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Mon Nov 24, 2014 4:58 am Post subject: |
If the water is collecting while it is parked, I highly doubt it is the pan gasket that is leaking. Maybe you can sit inside the car while someone sprays a hose in different areas. |
jlex Samba Member
Joined: January 23, 2009 Posts: 2902 Location: NW Pennsylvania
Posted: Mon Nov 24, 2014 5:33 am Post subject: |
Probably the rear window seal. _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Mon Nov 24, 2014 5:42 am Post subject: |
Water on the floor in the rear is often from the window seals. Make sure you check the padding and carpet in the package tray for moisture. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Mon Nov 24, 2014 6:41 am Post subject: |
Also, just in case... the inner rear wheel arches especially at the join with the floor pan are often rusted and filled and often not really watertight 'fixes'. There can also be rusted sections around the body to fender bolts which are 'hidden' by the fender welt, but can channel water into the back. A shitload of water can come in there during driving and a bit sitting depending on how it's all channeled... If it is really just from sitting then check the door and window seals. _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
Posted: Tue Nov 25, 2014 4:45 am Post subject: |
the rear trunk area is dry so the rear window is fine but i haven't looked at the side windows or the door seals. i'll get in while its raining next and have a look around. i'll jack her up as well and look for rust around the body fender join. it rained heavily late last might and i had a car cover over it and there wasn't as much water as their usually is so maybe it is just a seal !
thanks for the help everyone! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
D/A/N Samba Member
Posted: Tue Nov 25, 2014 5:51 am Post subject: |
If you want to find the leak, VW put out a dealer-level service manual for how to do so. Of course, I've seen this posted before in water leak threads and have even posted it myself and the OP's never seem to bother with it. For my money, though, it's probably a better idea to be systematic according to the OEM's techniques than to solicit lists of popular leak spots, no?
http://www.thesamba.com/vw/archives/manuals/looklisten_9.php
